This is a discussion on Car Shakes When Braking in the General Tech and Maintenance forum
ok guys when im braking from higher speeds, my whole car shakes. and not just a little bit, but there is a good bit of vibration in the steering wheel and it makes the car hard to handle while braking. does anyone know what could ...
| | #1 |
| ok guys when im braking from higher speeds, my whole car shakes. and not just a little bit, but there is a good bit of vibration in the steering wheel and it makes the car hard to handle while braking. does anyone know what could cause this? please help. |
| | #2 |
| Warped brake rotor. |
| | #3 | |
| I concur. I guess all that Quote:
. I feel you tho man, I think we've all been there, I mean every now and again you kinda have to slow down | |
| | #4 |
| Including the above mentioned suggestion, you might have an uneven grab of calipers. It's when one grabs a hold tighter than the other, know what I mean? This could be caused by air in the system or leaking seals. If that don't solve the problem then take it to the suspension shop. |
| | #5 | |
| Quote:
| | #6 |
| It could be a warped brake rotor, or if you have worn one of your pads so low that its to metal it would do that as well. I had that problem because the person who owned my car before me never changed brake pads and one of the rotors had been damaged so it ate pads in like 7500 miles. And when it would get low it would shake when braking. |
| | #7 |
| OR it could be a bad wheel bearing, put your front up on jacks and see if you can shimmy either wheel around, if so you should replace it immediately, if not fixed your wheel could just come off at any time, and we dont want that now do we! |
| | #8 |
| warped rotor. unbalanced wheel. warn pads. |
Similar Threads | ||||
| Rotated my tires, now the car shakes.... | CRX_m0nkey | General Tech and Maintenance | 9 | 04-09-2004 05:51 PM |
| 90 Civic HB shake while braking | starboy869 | General Tech and Maintenance | 10 | 10-06-2003 08:13 PM |
| The Shakes | crxjdm34 | HYBRID -> EG-EK / DC | 6 | 04-21-2003 06:07 PM |
| Prelude Braking System | 1991AccoLudeCoupe | Wheels / Suspension / Tires / Brakes | 2 | 04-06-2003 01:20 AM |
| Steering Wheel Shakes..tire Vibration.. | JrSiRb16A | Wheels / Suspension / Tires / Brakes | 6 | 03-03-2003 04:31 AM |
