Cel 10 OBD1
Old 09-14-2009, 01:56 PM   #1
Christmas Car
Ride:  93 4dr D15B, Greddy Short Ram, 4-2-1 Header, 2.5" Exhaust.
Rep Power: 8 RoughKnight has a spectacular aura aboutRoughKnight has a spectacular aura aboutRoughKnight has a spectacular aura about
Default Cel 10 OBD1
Yes, here we go. I took a few pictures to help out.
I'm running a D15B obd1(not 3stage), and code 10 keeps poping up. I'm pretty sure I have the right wires plugged. Also, where is the EVAP plug for the sensor? It's just dangling there...
Pics are in attachments. This is getting ridiculous, ever since I did this swap its been problem after fucking problem. This thread is on instant notification so I will answer back almost immediately.
It runs rich, and the tuner will NOT take my $450 to chip and tune my car until the cels are all gone. Lose lose situation so far.
RoughKnight is offline   Reply With Quote
Old 09-14-2009, 03:32 PM   #2
Christmas Car
Bump for shiny engine bay pic
Old 09-14-2009, 04:46 PM   #3
Rep Power: 1 tjscivic is on a distinguished road
I have been reading around and I came up reset the ecu if that dont work check the voltage at the harness side and if that dont work replace the sensor.
tjscivic is offline   Reply With Quote
Old 09-14-2009, 05:03 PM   #4
Christmas Car
Hmm...I'll show the Honda Manual to my mechanic and have him check the voltage from d15 to d22 and the other one, can't remember atm. It's just that I want to go boost, and the tuner will NOT let me tune the car for N/A (next year going turbo) for my 150hp goal if the ecu is still showing check engine lights. Is there any way to clean the sensor? Its the one adjacent to the drivers side, with two screws holding it and you have to plug it in facing directly up?
Old 09-14-2009, 05:59 PM   #5
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
you've got the wires plugged in wrong. that one that's just dangling (red and yellow) is for your IAT sensor. which is what's throwing your code. fix that and all should be well.
Anime Informant
reikoshea is offline   Reply With Quote
Old 09-14-2009, 07:08 PM   #6
Christmas Car
I tried replacing both into the slot where the one is now, and reset the ecu. Both dont work. I was researching and found out that the one with the SOLID red wire (the dangling one) is for my EVAP.
brand new iat sensor - Honda-Tech
2P IAT = Red/Yel and Grn/Wht
2P IACV = Yel/Blk and Grn/Wht
2P Purge Solenoid = Yel/Blk and Red
3P TPS = Yel/Wht, Red/Blu, and Grn/Wht
So what now?
Old 09-14-2009, 08:58 PM   #7
HS Troll...And Mod
reikoshea's Avatar
myspace
well you could do this:
pull the sensor. see how many ohm's its passing at room temperature (cold). Then use a hair drier on it for a minute or so. Test again. See you manual for acceptable readings. If they are out of range then the sensor is bad. If they are in range then the wiring is likely bad.
Anime Informant
Old 09-14-2009, 09:26 PM   #8
Christmas Car
Okay finally somebody on the right track,
In the morning, when I just fresh start the car, the cel comes on. After the car warms up to operating temp completely, the light goes away if I turn off/turn on the car. So i'm guessing thats your hairdryer trick. Now is it faulty? Or is the wiring faulty?
Old 09-15-2009, 12:49 AM   #9
HS Troll...And Mod
reikoshea's Avatar
myspace
its probably giving a bad reading in cold state (bad reading meaning reading outside of normal resistance).
Anime Informant
Old 09-15-2009, 08:28 AM   #10
Christmas Car
So does it need to be replaced? Or are my wires still messed up?
Old 09-15-2009, 09:34 AM   #11
HS Troll...And Mod
reikoshea's Avatar
myspace
replaced.
Anime Informant
Old 09-15-2009, 10:50 AM   #12
Christmas Car
kk i'll get on that
Old 09-15-2009, 10:56 AM   #13
Christmas Car
while we're on the subject
where does the evap plug go? I dont think i have the sensor for it or I need it cause its' not throwing a code
Old 09-15-2009, 12:57 PM   #14
HS Troll...And Mod
reikoshea's Avatar
myspace
I'd say RTFM for where the plug goes. As long as there's no CEL and you're not in cali it doesn't REALLY matter. just hope it doesn't end up in a ghost limp mode.
Anime Informant
Old 09-15-2009, 04:40 PM   #15
Christmas Car
RTFM?
Ravish The Fucking Manual?
And ghost limp mode?
Old 09-15-2009, 05:30 PM   #16
HS Troll...And Mod
reikoshea's Avatar
myspace
RTFM?
limp mode without a CEL. i made up the term
Anime Informant
Old 09-15-2009, 08:17 PM   #17
Christmas Car
hmm
does the old one off my d15b7 work? is there even one on that engine? I jsut went to the mechanics today and i saw he still has it there, maybe I could switch it up?
Tags
civic, d15b, intake, temperature
P28 OBD1 ECU P06 Chipped with OBD2 to OBD1 Harness RSS-Bot Auctions 0 03-29-2008 10:43 PM
obd1 gsr engine and harness -> obd2 Integra GSR-> obd1 Hondata ecu alterxerxes Integra 0 05-21-2007 03:25 PM
convert OBD0 to OBD1; need OBD1 injectors? suspendedHatch ECU's, Electronics, and Tuning 5 08-08-2006 11:21 PM
D16z6 obd1 harness on obd1 B16 in eg hatch bseriesautoparts ECU's, Electronics, and Tuning 1 08-02-2005 09:32 PM
WTB - OBD1 ECU. prefer a GSR - obd2a->obd1 harness chicken Parts: For Sale/Trade/Wanted 1 11-25-2004 03:28 PM
