This is a discussion on check engine light problem in the General Tech and Maintenance forum
i have had my check engine light come one about two times only in the hottest part of the day with the a/c on. then not reapear when i start my car again. today i jumped the service wire to check the code. but the ...
| | #1 |
| i have had my check engine light come one about two times only in the hottest part of the day with the a/c on. then not reapear when i start my car again. today i jumped the service wire to check the code. but the only thing flashing was the srs light help please i need to pass smog thru the ca state referee. thank you |
| | #2 |
| if this is a 95 prelude, the state ref can only check codes that are stored on the ecu. if you jumped the service connector, and the CEL didnt blink, you wont get flagged for CELs. |
| | #3 |
| thank you but the real problem is that my car didnt pass i was really high on hc and co i was wondering if the cel could lead me to why this was happening |
| | #4 |
| could be. if i were you id opt for a p72 tuned for 14.7:1 afrs and try it again. tuning to that afr usually lowers your hc and co emissions. As I said, the CEL MIGHT be causing the problem but until you can catch it and check it, theres not much that i can tell you. |
Similar Threads | ||||
| Check engine light on | nvrblkeme | HYBRID -> EG-EK / DC | 3 | 10-12-2005 09:21 AM |
| 98 civic o2 sensor / check engine light | malone68 | NorthEast | 1 | 07-12-2004 06:40 PM |
| check ENGINE light | HellBentHONDA | ECU's, Electronics, and Tuning | 4 | 05-04-2004 10:21 PM |
| Check engine light | Ractive78 | ECU's, Electronics, and Tuning | 0 | 08-22-2003 10:52 PM |
| Check Engine Light | Viperlocc_B18C1 | General Tech and Maintenance | 3 | 04-13-2003 12:27 PM |
