Hi all, ive got a problem with my clutch engage/disengagement point. I have to release the clutch pedal almost all the way to the top before the car moves. Its same with engaging, i only have to press it in about 1/4 of the way down and can shift. Im sure its supposed to engage/disengage about an inch or two off the floor! I've bled the clutch about ten times. i've adjusted the push rod on the master cylinder to shorten/lengthen it but no difference. The slave cylinder moves in/out fine when pressing the clutch, i dont know what else to try! Any help is appreciated! Thx
The clutch disengagement and engagement all depend on the clutch you are running. Stock clutch disengagement/ engagement should be in the center point. I use to have a xtd so call stage one clutch and it did the same thing as yours. Now I have a act and engage pretty low comparing to stock and the xtd clutch. So it could just be the clutch you are using.
D16z6 turbo- 14.2 @ 97 MPH 1/4 mile: RETIRE B20vtec Turbo in the making.... |
| Clutch pedal adjustment help | wanderinman | General Tech and Maintenance | 13 | 07-14-2005 02:45 AM |
| 88+ ECU Error Codes | pissedoffsol | Reference Materials | 1 | 05-19-2005 01:03 PM |
| My clutch needs help | jastunna1987 | General Tech and Maintenance | 2 | 02-03-2005 03:13 PM |
| 240 clutch adjustment | Dman1100 | Other Vehicle Discussions | 4 | 07-20-2004 09:41 AM |
| NOPI.com | rsaeini | Members' Lounge | 22 | 10-02-2003 03:07 PM |
