Facebook Twitter
clutch feels light..too light
This is a discussion on clutch feels light..too light in the General Tech and Maintenance forum
i got a new oem clutch from honda...the clutch feels way to light...i used brake fluid that "exceeds DOT 3 &4"....could that be the problem...also i bled lines correctly and refilled them correctly..no air..y does the clutch feel so light??...
Old 11-07-2003, 01:37 PM   #1
h22bubbleback is offline   Reply With Quote
Old 11-07-2003, 01:52 PM   #2
OEM honda clutches aren't very heavy....
liquid00meth is offline   Reply With Quote
Old 11-07-2003, 02:51 PM   #3
no you dont understand..this is LIGHT!
Old 11-07-2003, 04:11 PM   #4
ok...thats how they are. stock pressure plates feel like BUTTER. so yea, what did you expect? DMAN noobs
rudeludenotmeanthough is offline   Reply With Quote
Old 11-07-2003, 04:18 PM   #5
If it's working and engaging at the right point (IE, not with the clutch pedal 1 mm from the floor) then I wouldn't worry about it.
Honda manual transmissions rock*.
*At least compared to some other cars I've driven, which admittedly isn't a lot.
kaishaku is offline   Reply With Quote
Old 11-07-2003, 04:35 PM   #6
J
J's Avatar
Originally posted by h22bubbleback@Nov 7 2003, 11:37 AM
[b] i got a new oem clutch from honda...the clutch feels way to light...i used brake fluid that "exceeds DOT 3 &4"....could that be the problem...also i bled lines correctly and refilled them correctly..no air..y does the clutch feel so light??
I'm having the same problem, good engagement, but its so effing light. My buddies, pushes your foot off it when you go, mine is like, loose I swear yet it grabs strong and only slightly slips when I shift at high rpms.
J is offline   Reply With Quote
Old 11-07-2003, 05:01 PM   #7
Originally posted by Slammed89Integra+Nov 7 2003, 05:35 PM-->
Originally Posted by Slammed89Integra @ Nov 7 2003, 05:35 PM)
h22bubbleback
ITS STOCk... thats how they are.... end of story
Old 11-07-2003, 06:01 PM   #8
^ ^ im talking LIGHT..less than "butter" pethetically light
Old 11-07-2003, 07:21 PM   #9
if the clutch is engaging at the right point, and not burning, then it is fine.
If it's not, then there might be problem. If it's not engaging, and it's that light, then the pedal might not even be connected lol.
Old 11-07-2003, 07:30 PM   #10
92civicb18b1's Avatar
I got something of the same problem, my pedal is kinda firm a little low (does'nt seem to be a problem), but doesn't seem to engage. I just finished puttin the axles in and I started it up and let off the clutch, wheels didn't spin, but the speedometer went up, I don't have the linkage in so I'm not sure what gear it's in? Anyone know what the problem could be
92civicb18b1 is offline   Reply With Quote
How many forum posters does it take..... pissedoffsol Members' Lounge 51 11-30-2007 11:32 PM
clutch problem after swap welfare HYBRID -> EG-EK / DC 0 05-12-2004 10:51 PM
NOPI.com rsaeini Members' Lounge 22 10-02-2003 02:07 PM
Clutch Feels Funny hondadude199 General Tech and Maintenance 5 03-19-2003 01:53 AM
© 2001-2013 HondaSwap.com
