clutch pedal keeps gettin' stuck
Old 07-01-2003, 06:24 PM   #1
Rep Power: 14 riceburner5 is off the scale
i didn't drive my car for 3 weeks and when i pushed the clutch in, it stayed on the floor. i check my clutch fluid reservoir and it was empty. what could cause this? is my slave or master cylinder going out? pls. help and thanks
riceburner5 is offline   Reply With Quote
Old 07-01-2003, 06:33 PM   #2
Rep Power: 15 racerxb20z is off the scale
Send a message via Yahoo to racerxb20z
your clutch spring is out, time to pull the tranny
racerxb20z is offline   Reply With Quote
Old 07-01-2003, 07:40 PM   #3
Rep Power: 16 aznhottiekj is off the scale
you have a h22 in ur civic??
sweet man
aznhottiekj is offline   Reply With Quote
Old 07-02-2003, 01:57 AM   #4
Rep Power: 17 Dman1100 is off the scale
Send a message via AIM to Dman1100
Why would it be a spring when the fluid is gone? sounds like a leak to me
Dman1100 is offline   Reply With Quote
Old 07-02-2003, 02:31 AM   #5
Ride:  2006 Audi A4
Rep Power: 116 totalburnout has a brilliant future
totalburnout has a brilliant futuretotalburnout has a brilliant future
Send a message via AIM to totalburnout
yup. more than likely master/slave
i have a slight leak in mine too...my pedal has to be pumped to come back up and its a hydrolic clutch, i more than likely have a leak in one of the cylinders too
fill the reservoir up, bleed the lines, and u're good to go... temperorarly... obviously.
"Good talk... I'll see you out there."
totalburnout is offline   Reply With Quote
Clutch Pedal falls to floor when engaged ExplicitSnow General Tech and Maintenance 12 07-27-2004 11:22 PM
No Clutch Pedal no pressure RIT Civic HYBRID -> EG-EK / DC 32 11-10-2003 10:56 AM
hard clutch pedal rextec HYBRID -> ED-EF / DA 2 10-30-2003 01:01 PM
NOPI.com rsaeini Members' Lounge 22 10-02-2003 03:07 PM
What is double clutching? Calesta General Tech Articles 0 12-27-2002 03:06 PM
