when i am driving and push in the clutch to shift it sticks and then it just springs up, and my clutch doesnt disengage all the time either. would my master or slave cylinder be going out? I bled it and made sure it was full of fluid. what could it be. any help is appriciated.
im not sure about hydro trannies, but i know on cable trannies, there is a pedal return spring that pops the pedal back at you...thats what was wrong w/ mine on my crx...you might want to check that out...if your master/slave cylinder were the problem, your car probably wouldnt go into gear...that was my problem on my accord
I had the exact same problem with my 95 integra. It turned out to be that the slave cylinder was bad. Hope that helps
<a href=\'http://home.comcast.net/~projectxspeed/3rdgenteg.htm\' target=\'_blank\'>A Project in Progress</a> Get your ECU CHIPPED / buy ECU's CHEAP (uberdata, custom ecu maps, and more): <a href=\'http://www.hondaswap.com/forums/index.php?act=Msg&CODE=04&MID=36429 \' target=\'_blank\'>PROJEKTEG</a> |
