Clutch Problems
Old 03-14-2003, 09:57 PM   #1
Rep Power: 14 Racin'WithRice is off the scale
I need help!! The other day I tried to drive my '90 Prelude to work and my clutch didn't work at all!! I checked under the hood and found that my reservior was empty. I obviously have a leak somewhere. I topped it up with fluid and now it works again but it is slowly leaking.
Once I find the leak and replace the line, I have to bleed my system, but I don't know how. I've never done anything with a clutch before. Can anybody give me the basic steps to bleeding a clutch. Is it the same as brakes?
Also, I'm having problems locating performance parts, and asthetic parts for my car. Things like headers, exhaust, gauges, short shifters lowering springs etc. If you can give me the name of some companies that DO carry stuff for my car it would be greatly appreciated.
Thanx to all those who help me.
<span style=\'font-size:8pt;line-height:100%\'><span style=\'color:blue\'><span style=\'font-family:Arial\'>I've got it all; money, fame, a fast car, and a beautiful girlfriend......except for the money, fame, and car that is.</span></span></span>
Racin'WithRice is offline   Reply With Quote
Old 03-15-2003, 01:12 PM   #2
Can anybody help me???????????
Old 03-15-2003, 02:47 PM   #3
Rep Power: 16 omega11855 is off the scale
first of all if you have a leak your probably going to have to replace the hard line that take the fluid to the master cylinder if thats where it is leaking whatever once you replace whats leaking you need a friend friend in car pump clutch then holds the clutch to the floor and there is a little nozzle on the master cylinder open it and close it 8m openend wrench then repeat and dont for get to add fluid as you drain it while bleeding the system then your done oh yeah your done when bubbles of air stop coming out while your bleeding the system
&quot;Girls are like cars u can have as many as you can afford but you can only drive one at a time&quot;~Me
<a href=\'http://www.jzperformance.com\' target=\'_blank\'>Jz own meee</a>
omega11855 is offline   Reply With Quote
Old 03-15-2003, 03:41 PM   #4
So it is the same as bleeding brakes then. Cool. I can do that. Thanks for the help guy.
clutch problems stuntstere General Tech and Maintenance 2 07-27-2004 03:47 PM
clutch problem after swap welfare HYBRID -> EG-EK / DC 0 05-12-2004 11:51 PM
My transmission or clutch is acting up La_Pieuvre General Tech and Maintenance 6 02-06-2004 02:40 AM
My clutch isn't engaging! MarkJimenez99 General Tech and Maintenance 22 12-27-2003 11:25 AM
NOPI.com rsaeini Members' Lounge 22 10-02-2003 03:07 PM
