cold air intake
Old 07-20-2003, 06:13 PM   #1
Rep Power: 13 gonein11 is off the scale
I what to buy a new AEM V2 cold air intake for my 96 civic coupe w/b18b swap from a 99 integra ls. I cut a hole engine bay for the intake tube to go near the right tire, some friends say buy a ex CAI and some say go with the SI intake. On a different topic any suggeations on how to shave wieght i must keep the ac for my 1 yr old daughter and without losing saftey.
gonein11 is offline   Reply With Quote
Old 07-20-2003, 06:14 PM   #2
Rep Power: 29 rudeludenotmeanthough is off the scale
shave weight??.. i thought you were talkin about intake? try using periods, quotes, apostrophes, and such when you type.. it makes reading much easier. Have a nice day.
</div><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE (94RedSiGal @ Dec 2 2003 @ 12:27 AM)</td></tr><tr><td id=\'QUOTE\'>Having a ClubSi, Honda-Tech or HondaSwap sticker on them would just scream &quot;Steal Me Now! I'm a special car!&quot; to thieves.</td></tr></table><div class=\'signature\'>
rudeludenotmeanthough is offline   Reply With Quote
Old 07-20-2003, 06:34 PM   #3
Most any CAI will do the same job, some are larger in diameter and some step down in diameter as it gets closer to the TB. I always liked the iceman units since they were set up for both dry and wet setups along with a plastic material so they didn't soak up the heat under the hood. I also recommend the comptech icebox, that is what I am getting next most likely unless something more promissing comes out. Good luck.
Milan
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 07-20-2003, 06:48 PM   #4
My Vtec is biger then urs
jeffie7's Avatar
Rep Power: 283 jeffie7 has a reputation beyond reputejeffie7 has a reputation beyond repute
jeffie7 has a reputation beyond reputejeffie7 has a reputation beyond reputejeffie7 has a reputation beyond reputejeffie7 has a reputation beyond reputejeffie7 has a reputation beyond reputejeffie7 has a reputation beyond reputejeffie7 has a reputation beyond reputejeffie7 has a reputation beyond reputejeffie7 has a reputation beyond repute
Send a message via AIM to jeffie7
ebay go buy yourself a 20-30 buck one
I've done it before and would do it again
thats unless youre dumb enough to spend 200+ on an AEM
jeffie7 is offline   Reply With Quote
Old 07-20-2003, 10:42 PM   #5
Rep Power: 14 mariowc is off the scale
Send a message via AIM to mariowc Send a message via MSN to mariowc Send a message via Yahoo to mariowc
Or you could make your own that is better than the AEM's... AEM's are the near best on the market now, but they have a few flaws that could be fixed:
First, is their piping is made from aluminum... I dunno about you, but I don't want a conducter of heat on my cold air pipe. Your argument is... it's lighter. Mine is.. yes, but the difference is soo minimal... it's not even worth arguing.
Second problem - they are only ceramic coated on the outside. Doing a double ceramic coat you will keep your cold air much... errm, cooler than with only an outside coat.
And third: you can make this 'better-than-AEM' intake for 1/4 of the price.
Mario Masitti
Black 89 Prelude Si
B20A Boost Quarter 1 2004
mariowc is offline   Reply With Quote
Old 07-20-2003, 10:45 PM   #6
Rep Power: 59 hcivic.com is on a distinguished road
lose that fucking pic
hcivic.com is offline   Reply With Quote
Old 07-20-2003, 11:08 PM   #7
Ride:  DC2 ITR and DC4 LS
Rep Power: 19 Gen2Teg is off the scale
Send a message via AIM to Gen2Teg Send a message via Yahoo to Gen2Teg
get it for the Si. If you wanna spend the money then yeah, get the AEM V2. Need to lose weight? Get a carbon fiber hood and toss out your spare tire.
Gen2Teg is offline   Reply With Quote
Old 07-20-2003, 11:09 PM   #8
oh btw, why'd you cut a hole??? this is why you buy the product, read the instructions first, and then start the work. Not start the work, look for one, buy it, and realized you cut a hole for no damn reason.
Old 07-21-2003, 06:39 PM   #9
Thumbs up
Have seen the engine bay of a DX compared too a SI. there is hole that where the intake goes to the tire. I've seen EX's and SI's with cold air intakes and they go though a hole. the DX has to be altered, your not that big of a Honda fan as you think.Take a look at an SI or EX with a CAI
Old 07-21-2003, 06:43 PM   #10
umm either way.. you should of bought it and then cut it...
gsr into an eg...which cold air intake? indeskater HYBRID -> EG-EK / DC 3 07-19-2004 02:18 PM
F/S cold air intake for 90 to 93 accords WISCONSIN adaml2nv Parts: For Sale/Trade/Wanted 3 07-16-2004 09:50 PM
AEM COLD AIR INTAKE Langer Parts: For Sale/Trade/Wanted 1 05-31-2004 05:08 PM
Which Cold Air Intake to Use for 95 with B18 95hatchcx HYBRID -> EG-EK / DC 6 04-03-2004 05:55 AM
cold air intake vazfinestz General Tech and Maintenance 4 06-27-2003 03:48 AM
