compression ratio???
Old 05-24-2004, 08:49 PM   #1
The Seniorest Member....
scottp11's Avatar
Ride:  93 Civic CX w/ B16A ,T3/T4 Turbo
Rep Power: 31 scottp11 is just really nicescottp11 is just really nicescottp11 is just really nicescottp11 is just really nice
Send a message via MSN to scottp11 myspace
I currently go to school for automotive tech, and we learned about doing compression testing. We were taught that if you take the PSI minus 5, then minus 14.7, then divide by 14.7, you come up to your compression ratio, to one. And the same goes for the opposite if you have your compression ratio you can find what your PSI should be.
Well... I did my PSI on my JDM B16A and came out with 210 PSI for each cylinder.
If my math is correct, that means my CR is 12.9:1. I thought a JDM B16 CR was 10.4:1 and that would be about 175.5 PSI.
Was I tought wrong? Help me out if you know... Thanks.
93civicCXB16A...T3/T4 turbo
00civicSI...CRVtec
93integraLS...GSR
My build thread! : http://nwp4life.zeroforum.com/zeroth...d=27937&page=1
scottp11 is offline   Reply With Quote
Old 05-24-2004, 08:54 PM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
That's a very inexact way to guess your compression ratio... it depends on your cam profile and a bunch of other stuff too. If you have an intake cam that leaves the valves open after the piston starts moving up, you'll lose compression- you can also gain more depending on how your engine is set up too.
Old 05-24-2004, 09:01 PM   #3
Rep Power: 12 HondaCivicSiR93 is off the scale
Seems like a guess-timate type figure for a "perfectly" compressed car with absloutley no faults in the engine.
HondaCivicSiR93 is offline   Reply With Quote
Old 05-26-2004, 05:36 PM   #4
scottp11's Avatar
Whats the formula to find the REAL compression ratio? Thanx for your help!
00civicSI...CRVtec
93integraLS...GSR
Old 05-26-2004, 05:46 PM   #5
Calesta's Avatar
Ride:  2003 S2000
(volume of cylinder and combustion chamber @ BDC) / (volume of cylinder and combustion chamber @ TDC)
There you go.
Old 05-27-2004, 11:54 PM   #6
Blah blah blah....
MikeBergy's Avatar
Rep Power: 49 MikeBergy is on a distinguished road
Send a message via AIM to MikeBergy
Originally posted by Calesta@May 26 2004, 02:46 PM
(volume of cylinder and combustion chamber @ TDC) / (volume of cylinder and combustion chamber @ BDC)
There you go.
Mike, you need to invert that... other wise your cr comes out to less than one.
-1991 Integra, lots of goodies in an otherwise stock looking motorp; ITR front brakes.
-Xenocron programmable ecu w/datalogging port, LM-1 wideband, and Moates Ostrich are tuning tools of choice.
RIP 2005 Red Yamaha R6
www.m24x.com - Rocket Motorsports: For more technical engine discussions...
Radar will bounce off of a ride that is shiny and you keep clean.
Please don't PM me with tech questions. Use the forums!
MikeBergy is offline   Reply With Quote
Old 05-28-2004, 03:06 AM   #7
Calesta's Avatar
Ride:  2003 S2000
Whoops- same thing... it's still the compression ratio- it's just not the same convention that everyone's used to. I guess I'm used to dealing with compression as fractions of a whole, since you're making things smaller after all.
compression ratio = (volume of cylinder and combustion chamber @ BDC) / (volume of cylinder and combustion chamber @ TDC)
