compression test on 1st gen b16a
Old 08-22-2003, 11:36 PM   #1
Rep Power: 14 bryan is off the scale
i am looking for the compression specs for a 1st gen b16a i know that the ratio is 10.2:1 but i need the psi specs anybody out there know
bryan is offline   Reply With Quote
Old 08-25-2003, 04:31 PM   #2
Rep Power: 14 streetrays is an unknown quantity at this point
i don't know the compression on the spec you gave, but if you go ahead and do the compression test and all 4 cylinders are above, say, 150, and the difference is < 8% or so, you're fine..
Grand opening! NEW STORE LOCATION in AUSTIN!
http://www.streetrays.com
Warehouse Distributor and Dealer for the following:
TiAL, NRG, Avid Racing, Option DVD, PLX, Omni Power, Golden Eagle, Defi, GReddy, HKS, Megan Racing, ACT/XACT, Exedy, Magnecor, Blitz, BLOX, Apexi, Buddy Club, TEIN.
streetrays is offline   Reply With Quote
Old 08-31-2003, 03:56 AM   #3
Location: Southern IL, across the river from the Stl...
Rep Power: 17 nimblecivic is off the scale
Send a message via AIM to nimblecivic Send a message via MSN to nimblecivic Send a message via Yahoo to nimblecivic
not sure what the specs from honda are, but when I tested mine after the swap all the cylinders tested between 195-210psi...........
1993 Civic EX w/JDM B16a1 automatic swap
nimblecivic is offline   Reply With Quote
Old 08-31-2003, 10:38 AM   #4
Ride:  93 del Sol Gas sipper
Rep Power: 101 asmallsol is a jewel in the roughasmallsol is a jewel in the roughasmallsol is a jewel in the rough
I am pretty sure that Honda calls for the compression (at least on later b16's) to be 242 +or- 28 PSI for a new healthy cylinder. Make sure that when you run the compression test, you pull the fuse for the ECU, give WOT, crank over, stop when the needle stops jumping.
Collin
Material Science and Engineering
Michigan Technological University
Old 08-31-2003, 03:06 PM   #5
Rep Power: 27 SleEPeR_CRX is off the scale
my LS test was 180 across the board, a b16a should be alot higher b/c of vtec, so my guess is around 200-220
Sleepers Are the Only way to Go.
1990 CRX Si
B18a(92) CAI/E, Gutted, ACT clutch/pressure plate/13lb flywheel, Crower 403 Cams, Titanium Valve springs &amp; Retainers, Blockguard, Head Milled 20 thou, 9.8:1 Compression, AEM cam gears.
1/4 = 14.73
60' = 2.48
trap = 95.03mph
Soon to get: Header, Slicks
Future 13 second all motor LS!
SleEPeR_CRX is offline   Reply With Quote
Compression test results and ? hondadriver General Tech and Maintenance 17 07-10-2004 03:23 PM
H22 Compression test ohmstable HYBRID -> BA-BB /CA-CD 6 05-31-2004 01:42 AM
compression test for a ls motor erebunicrx General Tech and Maintenance 1 04-14-2004 11:40 PM
B16A Variants pissedoffsol Swap Articles 0 01-12-2004 02:31 AM
Static vs. Effective Compression pissedoffsol Turbo Information 0 01-12-2004 01:43 AM
