| | LinkBack | Thread Tools |
| | #1 |
| Senior Member | So I went and got the gauge set from orielly's today and checked my compression. I did it three ways because I was getting funky readings the first two times. The first time I checked it was with all the plugs in except the cylinder I was checking compression on (obviously) and with the fi/em fuse still in. The results were:: D 120 120 130 120 T The second time I checked all the plugs were in but with the fi/em fuse pulled. The results were: D 170 170 180 170 T The third time was with plugs out and fuse out. Also I cranked the car untill the needle on the gauge stopped building (I was figuring this was the correct way to go about it). The results were: D 215 215 220 215 T Does the third method/numbers seem correct for a b series vtec motor?? Jdm B16 to be exact. Also I have heard that differences in the numbers isn't a good sign. What would cause a slight change from cylinder to cylinder. Also the D signafies dizzy side and T signafies timing belt side... for those that have no common sense |
| | #3 |
| Junior Member | Difference in compression is usually a headgasket or rings problem. Here's the write up from the tech articles. I'd just quote it but I don't know how to do that. I don't think you have a problem with yours being so close together though. How to: Leak down and Compression tests Last edited by cashen; 06-19-2006 at 09:15 PM. |
| | #5 | |
| Senior Member | Quote:
| | #7 |
| Senior Member | The throttle open?? I never thought of that... would this make any difference? Thanks for all the replys to this but I'm not really looking for advise in the numbers more or less just the method in which it was done with the corresponding numbers. |
| | #8 |
| TTIWWOP Join Date: Dec 2002 Location: 845 Area, NY Age: 30
iTrader: 0 / 0% Ride: 90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
Rep Power: 515 | of course it would, lol the throttle body being open = no air restriction you would get your peak reading faster, but since you let it spin until it the needle stopped moving then it would all be the same in the end... |
| What did your compression test read? | phyregod | General Tech and Maintenance | 28 | 11-18-2009 05:17 PM |
| All Swap Info for EF | Riceras | HYBRID -> ED-EF / DA | 2 | 02-07-2005 02:20 PM |
| Compression test results and ? | hondadriver | General Tech and Maintenance | 17 | 07-10-2004 02:23 PM |
| compression test for a ls motor | erebunicrx | General Tech and Maintenance | 1 | 04-15-2004 10:52 AM |
| Static vs. Effective Compression | pissedoffsol | Turbo Information | 0 | 01-12-2004 12:43 AM |
