CRX B18A1 swap problems
Old 10-21-2009, 02:11 PM   #1
Greenhorn
Rep Power: 0 jmiz69 is on a distinguished road
Exclamation CRX B18A1 swap problems
well here it goes i got a crx the other day and it has a b18a1 swapped into it i can turn the car on and it drives good like it should until it gets to about running temp and then it starts to bogg when i take off and it dosent go away till its like at 3500 rpms i was thinking its the wiring for the oxygen sensor but i dont have a diagram does anybody have any other sugestions or a wiring diagram for a p75 ecu it has a jumper harness to the motor harness to the i got the car like this and i can say the people that did the swap were real dumbasses like the fan was on the wrong side of the radiator and things like that would appreceiate the help
thanks, Jesus
jmiz69 is offline   Reply With Quote
Old 10-27-2009, 08:55 PM   #2
Prof. Bottles
mikey bottles's Avatar
Ride:  Swapped 88' Rex
Rep Power: 14 mikey bottles is a jewel in the roughmikey bottles is a jewel in the roughmikey bottles is a jewel in the rough
Send a message via AIM to mikey bottles myspace
dont know if youre still having the problem, but ive seen it where the dizzy works great until the motor gets to about running temperature, the dizzy gets hot and starts to act up, if you have a spare, good dizzy, try swapping it and see if it helps.
"LAYIN' IT DOWN ON THE STOMPIN' GROUND SINCE 1985" NJ856!
mikey bottles is offline   Reply With Quote
new b18a1 in rex problems pappaj HYBRID -> ED-EF / DA 7 09-19-2008 12:50 PM
b18a1 problems skillz2k5 HYBRID -> ED-EF / DA 11 02-26-2007 02:04 PM
b18a1 swap problems hatdude4 HYBRID -> ED-EF / DA 12 11-07-2005 01:27 PM
'90 CRX with B18A1...Rev Problems '90ShowCRX HYBRID -> ED-EF / DA 1 06-16-2004 06:41 PM
Problems b18a1 swap SLOWHONDA General Tech and Maintenance 1 10-12-2003 05:39 PM
