Hi sir ,
I am using Honda Civic 92-95 4drs B16A DOHC Vtec Manual trans. Just want to confirm whether the ECU of D15B SOHC Vtec can be use in my B16A engine ? I had try to plug in the D15B ECU into my car and start the engine , no CEL , engine running fine , Vtec engage at 5000rpm and rev cut at 7500rpm. Need your help to confirm for me if i am using this D15B ECU into my B16A engine will it be harmful ? Thank you ........... |
Running on two cylinders
Ride: 2000 Mitsubishi Lancer RPW E5 Coupe
i would run a B16A ECU.
you might be running a bit lean, since the B series requires slightly more fuel. __________________
Home of the RPW built 2000 Lancer CC Coupe. See what is done to the little Evo5. "If you don't like what I've done with my car, I will gladly refund all the money you put into it." |
