delay timing
Old 06-26-2005, 12:44 PM   #1
mozzandherb is off the scale
I've heard that if your running nitrous you should retard your timing depending on how much the shot is, however I also heard that if you advance your timing you can gain a little more horsepower now I don't know if that's with or without nitrous. Anyway my question is when I add the nitrous should I retard the timing even if I'm just using the nitrous and the track twice a month? I drive the car daily so I don't know if it's a good idea to delay it if I'm only going to use the nitrous once and a while.
mozzandherb is offline   Reply With Quote
Old 06-26-2005, 01:30 PM   #2
learning in progress
formby's Avatar
formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
for every 50 shot 2deg retard.....use a colder plug....ngk bkr7e is what i use....and i retard the timing only when i know i will use the nos...which is sat night and track days....nos is not something i would recomend using everyday...specialy on stock internals....
