well i have a slight delimma with my 89 si. just recently the e-brake light on my dash started to stay on and i dont know why. sometimes it turns off, sometimes it doesnt. its starting to drive me crazy because i dont know what the hell it is, i checked the switch for the e-brake and it still doesnt do anything. i even took the wire off the switch and it still stayed on. . . im just a bit confused. . . bad switch maybe?
and to top it off, it turns off and on somtimes on its own. . . blahhhhh someone help, ne ideas? also does that brake light on the dash mean anything other than the e-brake? |
HS Troll...And Mod
Ride: 2001 Honda S2000
it could be the switch. when the switch is open (meaning the wires are not connected) the light comes on. when you put it down the switch is pressed and the light turns off (which is why pulling the wire didnt do anything). so its a very good possibility that it is the switch causing the problem.
If you PM me with tech questions, you better have a link to the thread in your PM. Anime Informant |
Ride: i have 14 cars i drive my sohc turbo ef
check ypur brake fluid it could be low also
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS. |
Just ground that wire out and remember to pull up the ebrake whenever you park.
96 LX 4dr. with B18a, PR3 pistons, B16 head w/ port 'n polish to intake, CTR intake/exhaust cams, ITR IM, CTR TB, Hondata IM gasket, RC 310cc injectors, Denso Iridum plugs, Skunk2 valve springs/retainers, Excedy race clutch, ACT streetlight flywheel, Walbro 255 fuel pump, GSR tranny, and Tanabe Super Racing Medalion...., next is Header and VAFC. Best run on 1320: 14.5 @ 94.5mph street tires 14.4 @ 94mph small slicks :P 98 Yamaha R1 |
#6 |
my vote goes to the brake fluid level being low
#7 |
naw brake fluid level is fine, i forgot to add that it turns off sometimes and goes back on. But when the light is off i can turn it on and off with the e-brake by pulling it up or pushing it down. . . this leads me to belive its the switch, i didnt think about grounding the wire untill i put all the covers back on =T. . .
#8 |
sounds like the brake fluid is low to me
| Brake Lights out | HatchSpeeD | General Tech and Maintenance | 0 | 07-24-2004 08:24 PM |
| Check engine light not staying on | hondaflr | General Tech and Maintenance | 1 | 06-14-2004 10:18 PM |
| Brake Light Electrical Problem | Psyco609 | ECU's, Electronics, and Tuning | 1 | 06-09-2004 01:17 AM |
| Foot Brake Light issues | millsatheart | General Tech and Maintenance | 0 | 08-14-2003 07:52 PM |
| Brake Light Troubles | Ludelover | General Tech and Maintenance | 5 | 08-14-2003 07:47 PM |
