Ek cooling fan not turning on,HELP PISSOFFSOL!
Old 09-25-2006, 02:02 AM   #1
Rep Power: 8 96EKB18C5 is on a distinguished road
Default Ek cooling fan not turning on,HELP PISSOFFSOL!
I own a 96 e coupe with the "grocery get'in" D16Y8. My cooling fan stopped working so I checked for the ovious, first relays, fuses,fan motor(repaced)and found nothing.So I spliced off the wire that runs the fan to a toggle switch to run it when it gets hot. Next weekend I'm doing my b18c5 swap(FINALLY!).I'd like to have the fan work normally (without the switch) so I don't forget to turn it on an cook my engine. Is this a common problem?
96EKB18C5 is offline   Reply With Quote
Old 09-25-2006, 02:06 AM   #2
That was a EX coupe, i typed too fast whoops!
Old 09-25-2006, 08:32 AM   #3
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 338 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
you should check the coolant temperature sensor. i think that is what turns on the fan.
why not wire up the fan to switched ignition so its always on when the key is on?
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 09-25-2006, 09:55 PM   #4
Good idea, will that mess with any ignition fuses?
Old 09-26-2006, 12:49 AM   #5
nopers
Old 09-26-2006, 05:41 PM   #6
Blah blah blah....
MikeBergy's Avatar
Rep Power: 49 MikeBergy is on a distinguished road
Send a message via AIM to MikeBergy
I don't know if it's the same on a D series motor as on a B series, but there is a temperature switch on the backside of the block that turns the fan on, not the cts. The cts is only for the ecu and coolant temp gauge.
-1991 Integra, lots of goodies in an otherwise stock looking motorp; ITR front brakes.
-Xenocron programmable ecu w/datalogging port, LM-1 wideband, and Moates Ostrich are tuning tools of choice.
RIP 2005 Red Yamaha R6
www.m24x.com - Rocket Motorsports: For more technical engine discussions...
Radar will bounce off of a ride that is shiny and you keep clean.
Please don't PM me with tech questions. Use the forums!
MikeBergy is offline   Reply With Quote
Old 09-26-2006, 06:52 PM   #7
GSRCRXsi's Avatar
Rep Power: 88 GSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of light
mike on newer b series the switch is on the thermostat. the 1 wire sensor on the head is for the guage. and the one for the ecu is a seperate one on the head. i think its the same on newer d series too, but i could be wrong
91 CRX si
95 Integra LS
Originally Posted by 90 accord
i have a lady, of over a year and a half now, and she likes the plug more
87 CRX DX cooling debacle - complete stumper Neutrino Civic and CRX - EW 3 09-05-2006 12:51 AM
HELP. Vibrations everywhere when going straight and turning right. No NSXguy HYBRID -> EG-EK / DC 1 12-29-2005 08:00 PM
Turbo cooling: water lines radnulb Forced Induction 4 03-04-2004 09:03 AM
cooling fan not turning on cycloneb18c3 HYBRID -> ED-EF / DA 2 08-19-2003 02:33 PM
Cooling Fan randerson165 General Tech and Maintenance 15 06-26-2003 01:31 PM
