engine code 6
Old 09-08-2003, 03:39 PM   #1
Rep Power: 28 rsaeini is off the scale
ok, i finally put the civic back together yeterday and when i finally got around to starting the damn thing up i'm getting a check engine light, code 6. i know the code is for the "engine coolant temprature sensor and circuit" but i wanna know if any one ever gotten this before.
if so, what was the problem with your particular case. what did you have to do to fix it.
this happened late last night and i was too damn tired to look to try to figure out the problem. i put the motor back in yesterday and refilled the radiator, i plugged everything back in like it was supposed to be and then this happened. the engine runs fine but the check engine light is there and i don't want to risk driving it cuz i don't want the car to overheat or anything.
i'm going to check it out when i get home but i wanted to get some suggestions.
"let those who judge me burn in hell until their Hondas are repossessed" - ME 1.6-1.8
rsaeini is offline   Reply With Quote
Old 09-08-2003, 06:05 PM   #2
doesn't anybody know.
Old 09-08-2003, 09:15 PM   #3
tab
Ride:  03 Avalanche
Rep Power: 51 tab is on a distinguished road
Send a message via MSN to tab
I can't tell you what the problem is, BUT....You should know that there is at least one temperature switch(for your fan), maybe two if you have AC(condenser fan). The small sensor looking thing on your head is a temperature sender(signal to your dash). Last but not least, you will have a temperature sensor. The sensor is the one that sends the signal to your computer. A good schematic will show you which it is. Test the sensor. Make sure your fan is working properly. It is possible to cross up your harness plugs. Fan and Sensor might be swapped, if it is not the stock harness. Hope I helped.
2003 Chevy Avalanche
Leather, Moonroof, Z71, tow package, bose+six disc, nice.
1992 Accord EX (sold to good friends)
JDM H22A
H22A Auto Tranny w/LSD
I/H/E -- All stainless w/2.5 inch Catback
1968 Oldsmobile Toronado
Project car, 455 ci front wheel drive, nasty.
Old 09-09-2003, 10:25 AM   #4
yeah, ummm...i sort of knew all of that already.
P1457 code help hondadriver General Tech and Maintenance 7 06-11-2004 09:43 PM
HELP! d16y8 into my 92 Si civic_rider HYBRID -> EG-EK / DC 5 01-01-2004 11:16 AM
Check Engine Code 43 Came Up! importimage ECU's, Electronics, and Tuning 2 06-06-2003 09:29 AM
My Engine Swap Continues rsaeini HYBRID -> EG-EK / DC 23 03-22-2003 03:22 PM
Sir Engine Code? civic89sir HYBRID -> EG-EK / DC 2 03-17-2003 11:00 PM
