Engine code?
Old 11-12-2006, 02:02 PM   #1
Rep Power: 7 jeff roys is on a distinguished road
Default Engine code?
I'm a new honda owner and want to know if anyone knows where to find the engine code, b16 etc. I bought a 94 del sol and it does not have any badges or marking on the outside. The top of the engine says v-tec, any ideas, thanks.
jeff roys is offline   Reply With Quote
Old 11-12-2006, 03:09 PM   #2
Default Del sol
Thanks, if that is the case, do you happen to know the specs on that engine? I was hoping to have the 160hp version.
Old 11-12-2006, 03:15 PM   #3
Soy Boricua
Estorvito's Avatar
Ride:  BoOsted fodo civic
Rep Power: 32 Estorvito will become famous soon enough
Send a message via AIM to Estorvito Send a message via MSN to Estorvito myspace
Honda Engine List
^^^ It sounds to me like its a d series. check out link above.
Good Luck
LBR=LowBudgetRacing
My civic build thread
Estorvito is offline   Reply With Quote
Old 11-12-2006, 03:23 PM   #4
Its a si, I was hoping I had the 160hp doch vtec. It is a v-tec soch but it only has 125hp. I bought it with mods but I have no idea where it is at currently.
Old 11-12-2006, 10:10 PM   #5
Default mods
It has an AEM air intake, carbon fiber muffler, aftermarket race headers, and I am told it has a chip(mugen). Not sure where the ecu is so I am not sure how to check. I am told I can put my car on a dyno nearby fo 20 bucks so I may do that sometime. For now I am just gonna work on the inside with some white face gauges and stuff like that.
Old 11-12-2006, 10:28 PM   #6
2265787829
2000Si's Avatar
Ride:  Refer to my name, dumbass.
Rep Power: 285 2000Si has a reputation beyond repute2000Si has a reputation beyond repute
2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute
The ECU should be under the carpet on the passenger side in front of the door.
XBL: jams 8201 (14,580G)
Lego Sears Tower: 82 stories/75.9% complete
CL2, CL3, CL4, CL5, CL6, Car, Mortgage
Originally Posted by eg6sir View Post
yea.. but aren't you spaghetti noodles covered in skin?
2000Si is offline   Reply With Quote
Old 11-13-2006, 01:59 AM   #7
He who burns the rubber.
kkid28's Avatar
Ride:  `91 Cutlass Supreme
Rep Power: 7 kkid28 is on a distinguished road
Originally Posted by Blanco View Post
I'd get a stock program back into the ECU because those "Mugen" chips just dump a lot of fuel in. Also, stay away from the white faced gauges because it's really easy to screw up your tach and speedo.
Might accidentally think you're going 6mph at 120000 rpm or something? lol How would you screw them up?
Tim Horton's take over in Canada plan completion... |||||||||| 90%
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
kkid28 is offline   Reply With Quote
Old 11-13-2006, 08:34 AM   #8
I have wondered why I was not getting the fuel economy I thought I should out of a four banger! I have been doing some research on the gauges, would you guys still not recomend them if they were installed by someone who knows what they are doing? How about a race style steering wheel, are those hard to do?
Thanks for all yous guys input!
Old 11-13-2006, 08:35 AM   #9
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
Check my sig for installing a "race style" steering wheel.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-13-2006, 12:36 PM   #10
Thats awsome, thanks!! Do you have anything on white face gauges?(the cool multi color ones)
Old 11-13-2006, 03:30 PM   #11
Andrew's Avatar
Ride:  1991 CRX Si
Sry I don't. I've never messed with them, and probably won't ever do 'em... it's just not my style.
Just be carefull and follow the instructions carefully.
I'm sure you can find info online somewhere.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-13-2006, 06:13 PM   #12
Default Gauges
I believe you, but it just seems so screwed up. I have heard so much about this and WILL heed the warnings. I just don't understand why you can't replace the needle at 0 and be ok. I have been calling around and will end paying someone to do them. Any way to tell if they have been jacked up or do I just cross my fingers?
Old 11-13-2006, 06:17 PM   #13
Andrew's Avatar
Ride:  1991 CRX Si
Is it that important to you?
I'm not saying, "don't do it", but, if theres risk of messing up your cluster, why bother with it?
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-13-2006, 06:33 PM   #14
Just beacuse I already bought them from ebay.
Old 11-13-2006, 06:33 PM   #15
I guess you are right in the long run though.
Old 11-13-2006, 08:05 PM   #16
I guess that is always an option! Now I guess I will just redirect my efforts somewhere else.
Engine Code. What engine do I have? raidmax General Tech and Maintenance 9 09-24-2006 10:42 AM
engine code 43 b18a1 in 91 civic hatch drifter0020 Civic and CRX - EF 3 07-26-2006 02:40 AM
obd1 engine code? C-Bye General Tech and Maintenance 5 10-15-2005 09:53 AM
Check Engine Code 43 Came Up! importimage ECU's, Electronics, and Tuning 2 06-06-2003 09:29 AM
Sir Engine Code? civic89sir HYBRID -> EG-EK / DC 2 03-17-2003 11:00 PM
