Engine died, can't figure out what's wrong!
Old 07-29-2004, 01:03 AM   #1
$k@m Art1$t is off the scale
Last Friday my 89 Civic Si died on me for the first time. I can't seem to figure out what's wrong. The past 3 days before the car died, there were moments where the engine would stall and lose all power for a few seconds and then everything would be back to normal. Basically all power was lost even when I was trying to accelerate, this happened at least twice a day. I've hard wired the fuel pump to see if the engine is getting fuel and its got fuel all the way to the fuel rail. However, no fuel will come from the main fuel line when I turn the ignition on. I tested the main fuel relay and that works fine. Does anyone have any clues? The engine rotates fine and it sounds like she wants to start but won't. Only other thing I can think of is the pressure regulator or something else electronic that controls the fuel.
$k@m Art1$t is offline   Reply With Quote
Old 07-29-2004, 03:59 AM   #2
I'll be back...
B16RacerN2NR's Avatar
Ride:  96 DB8, 06 Mazda 5
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
have you checked to see if it's getting passed the injectors?
B16RacerN2NR is offline   Reply With Quote
Old 07-29-2004, 05:06 AM   #3
No, I haven't. It was getting late when I was doing these tests and didn't want to bother with checking the injectors yet. I've read some articles on the internet and many of them point to the main fuel relay. I've had past problems when the car didn't start when the motor was hot for a few minutes, then all of a sudden it worked normally. My car is pretty old and I live in Hawaii where it's hot and humid all year, which would wear out that relay quicker than in most other places. I'm not sure though, because I did the three continuity tests and they all passed. You guys think the relay could be a big possibility for the car not starting? The relay clicks when I turn the key on, but the fuel pump does not click on like it should. Dunno if its the wiring harness or the relay itself. It can't be the fuel pump cause it works and pumps when I connect it directly to the battery.
Old 07-29-2004, 11:57 AM   #4
TTIWWOP
reckedracing's Avatar
Ride:  90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
reckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
reckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
The only reason I even checked mine was because the steering column started smoking a few weeks ago.
whoooaaaa... i would have checked it too
lol
i hope you carry a fire extinguisher now...?
you may want to check your distributor...
the screw on my rotor inside the distributor decided to take a walk, and i guess this has happened to other people as well...
reckedracing is offline   Reply With Quote
Old 07-29-2004, 12:40 PM   #5
B16
B16's Avatar
B16 has a reputation beyond repute
B16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond reputeB16 has a reputation beyond repute
Send a message via ICQ to B16 Send a message via AIM to B16 Send a message via MSN to B16  FaceBook
yes, that has happend to me before
Old 07-29-2004, 01:51 PM   #6
B16
B16's Avatar
sometimes what you think is shaft play is actually play where the rotor meets the shaft, that part can get kinda bent out of shape and give some play
Old 07-29-2004, 06:58 PM   #7
tab
Ride:  03 Avalanche
tab is on a distinguished road
Send a message via MSN to tab
I've also heard that when the ignitor in the distributor is going out, the car will die when warm, and start back up after cooling off.
Old 07-31-2004, 09:31 AM   #8
ohmstable is off the scale
Originally posted by $k@m Art1$t+Jul 29 2004, 05:06 AM--><div class='quotetop'>QUOTE($k@m Art1$t @ Jul 29 2004, 05:06 AM)</div><div class='quotemain'><!--QuoteBegin-B16RacerN2NR@Jul 29 2004, 03:59 AM
[/b][/quote]
If your fuel pump is not priming I'd double check the main relay. Just because it clicks doesn't necessarily mean it's working. The solder connections inside tend to break. I'd rip out the relay and resolder all the connections.
-|\/\/\/\/\|- Ohmstable
ohmstable is offline   Reply With Quote
Old 07-31-2004, 03:34 PM   #9
rudeludenotmeanthough is off the scale
rotor took a walk on my like a week ago. took me 2 mins to figure it out.
rudeludenotmeanthough is offline   Reply With Quote
