Engine Wire harness compatibility
Old 01-25-2005, 07:08 AM   #1
Rep Power: 0 zumbate is off the scale
I have a Engine Wire harness from a 92-95 Civic VTEC. Will it fit a D16z6 vtec motor. The car is not wired for vtec. Will the harness from 92-95 civic wire to the car or no? sorry, the car is a 88 honda crx si. The motor is from a 95 honda del sol si
thanks
zumbate is offline   Reply With Quote
Old 01-25-2005, 08:28 AM   #2
FüK-VTEC
civicious's Avatar
Ride:  07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
Rep Power: 189 civicious has a reputation beyond reputecivicious has a reputation beyond repute
civicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond repute
Send a message via AIM to civicious myspace
No, a 92-95 harness will NOT fit in an 88 CRX Si. You're gonna have to use your stock harness, and add the wires for VTEC, VTEC oil psi, knock sensor, and also run a 4-wire o2 sensor. In addition, you're gonna need an obd0-obd1 jumper and a P28 (since the only obd0 vtec ecu was a pr3, for a DOHC, and it'll make the Z6 run rich as fuck).
CMRA #265
http://www.myspace.com/civicious
AIM: greyfades
civicious is offline   Reply With Quote
