| | LinkBack | Thread Tools |
| | #1 |
| Member | ok... i did search for this and couldn't find quite my problem explained.... (i have a 90 crx si) my idle would rev it self up to about 2500 then drop to 700 and repeat... just rev it self... and pretty quickly... (this was about a week ago) the ecu was throwin a code 1 (02 sensor) so i went ahead and replaced that... the problem seemed to go away for a little bit... but now its back... and not at every light.... like every 3rd light i'm sitting at in neutral it'll start doing it... i've replaced my fuel filter (as it needed it anyways) and tried using anohter o2 sensor... if anyone else has had this problem and can give me some possible soloutions that would be great.... thanx guys my only geuss is that it could be a map sensor or a tps???? but i'm not too shore and don't have $$ to throw into tons of parts for trouble shooting... but may have to |
| | #2 | |
| Member | Quote:
| | #3 |
| Senior Member | When you removed your O2 sensor, was it all fouled up ( covered in black crap?) I'm also having t he same problem, but not as big of a jump, it will idle at about 1000rpm, then jump to 1500-1700 then drop down. i have no idea what it could be, becuase it did the exact same thing w/ my d16a6 and now it does it with my ZC... nathan |
| | #5 |
| Super Moderator Join Date: Sep 2002 Location: New Albany, OH
iTrader: 0 / 0% Ride: 01 is300, 05 s2000, 03 rx300
Rep Power: 58 | http://www.hondaswap.com/~pills/idlefix.html there is a quick list of fix its.. in addition you may want to bleed your coolant to be sure there is no air in the system. |
| extremely erratic idle | evilgsr | General Tech and Maintenance | 8 | 04-22-2007 02:48 AM |
| Fixing an erratic Idle | pissedoffsol | General Tech Articles | 2 | 10-22-2004 12:24 PM |
| HONDA IDLE PROBLEMS 92-95 CIVIC | FamilyD | General Tech and Maintenance | 0 | 05-14-2004 10:07 PM |
| Idle problems with h22 | driver1 | HYBRID -> BA-BB /CA-CD | 15 | 10-09-2003 09:36 AM |
| idle problems | slohnda | General Tech and Maintenance | 6 | 10-05-2002 12:05 AM |
