ERROR CODE P1162 : Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow Response
Old 02-13-2007, 04:13 PM   #1
GreenMcNasty's Avatar
Ride:  2000 Honda Civic HX / 2005 Scion tC / 1991 Explorer
Rep Power: 15 GreenMcNasty is off the scale
Send a message via AIM to GreenMcNasty
Default ERROR CODE P1162 : Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow Response
I Got this code on my 2000 Honda Civic HX. Is this the O2 sensor? And if it is, which one? Pre or post cat?
GreenMcNasty is offline   Reply With Quote
Old 02-13-2007, 04:22 PM   #2
Originally Posted by Blanco View Post
Use this link (88+ ECU Error Codes) and pull your code like that.
Yeah that's where I referenced the code but I'm a bit of a tard and I'm not sure where the air/fuel sensor is!!
Old 02-13-2007, 08:54 PM   #3
Ancient Member
welfare's Avatar
Ride:  RHD EG6 jrsc b18c :)
Rep Power: 29 welfare is a jewel in the roughwelfare is a jewel in the roughwelfare is a jewel in the roughwelfare is a jewel in the rough
Send a message via AIM to welfare
Checked my alldata, p1162 is slow responce for o2 metering, sensor 1
which you knew
it is your o2 sensor
Pre cat
just replace it, but use a good quality replacement such as bosch or go oem.
DO NOT BUY ONE YOU HAVE TO WIRE TOGETHER,they may be cheaper, but they are a pain in the ass and if you don't do it right you can wreck the sensor the first time you run the car.
welfare is offline   Reply With Quote
Old 02-13-2007, 08:59 PM   #4
which you knew
Pre cat
Awesome. Perfect info! Thank you! I'll avoid the "do your own wiring" and go oem.
Old 02-14-2007, 03:57 PM   #5
Ancient Member
welfare's Avatar
Denso is good, too. You can get them from RyWire.com for a decent price.
Agreed
Old 02-17-2007, 03:16 PM   #6
Ok, this car has a 5 wire pre cat O2 sensor. I looked on rywire and all they have is the four wire. Any suggestions as to where I can get the 5 wire? Autozone/Napa/ ect wanted $400-600 for the 5 wire and that is just insane!
gsr whp 94_gs-r Engine Building 100 01-15-2007 10:00 AM
88+ ECU Error Codes pissedoffsol Reference Materials 1 05-19-2005 01:03 PM
what is the use of installing Air/fuel ratio gauge natecspecr ECU's, Electronics, and Tuning 10 05-05-2005 03:35 PM
All Swap Info for EF Riceras HYBRID -> ED-EF / DA 2 02-07-2005 03:20 PM
