A/F ratio meter
Old 09-14-2003, 05:53 PM   #1
Rep Power: 29 rudeludenotmeanthough is off the scale
Which O2 sensor do i hook up the A/F ratio meter to?
Here is the instructions that i got from Auto meter, Auto meter.
And here are some pics of what im dealing with.
</div><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE (94RedSiGal @ Dec 2 2003 @ 12:27 AM)</td></tr><tr><td id=\'QUOTE\'>Having a ClubSi, Honda-Tech or HondaSwap sticker on them would just scream &quot;Steal Me Now! I'm a special car!&quot; to thieves.</td></tr></table><div class=\'signature\'>
rudeludenotmeanthough is offline   Reply With Quote
Old 09-14-2003, 06:02 PM   #2
Banned
Rep Power: 0 Tonyd0821 is off the scale
Send a message via AIM to Tonyd0821
are you boosted? if not, then why the need for a a/f guage?
whats the volt guage for, aside from the obvious....
Rsaeini hooked up my a/f guage. if he sees this thread tomorrow, im sure he'll be able to explain to you how to do it
p.s.
i was under my hood this weekend, and happened to notice a few of the wiring jobs he did for me when he helped install my turbo....
Top notch work to say the least
instead of splicing both wires, and attaching them with some electrical tape...
he took the time to cut off a section of the insulating material and then somehow slide the wire in, and wrap it all up in a nice little package....
i was impressed
Tonyd0821 is offline   Reply With Quote
Old 09-14-2003, 06:02 PM   #3
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
do you have a wideband o2? then why the need for a worthless reading.
Old 09-14-2003, 06:03 PM   #4
Banned
where do i get a wideband o2 from? how much do they cost?
how hard are they to install.
Old 09-14-2003, 06:09 PM   #5
i had bought a prelude with hella mods on it already. The car already had those, so i just decided to take what i can before i ditch the other car. The car HAD ground control, tokico illumina blues, teg rims, cam gears, DC sports header 4-2-1, intake, relocated battery kit, front and rear strut bars, and those gauges, and a few othe misc things. Can i get any help on the install proccess?? I just want to out it in and have it work, not like theres a need for it anyways, like what was already stated. So yea.... Thanx for the replies, can i haver more?
Old 09-14-2003, 06:29 PM   #6
Rep Power: 13 OZRacing is off the scale
Send a message via AIM to OZRacing
Is there's a O2 sensor before the cat???
If not just hook up to either one, and make sure you ground the A/F gauge directly to the battery. If not it would read wrong!!
Swaping into a B is the gayest thing you can do!!!
YOU'RE ALL GAY!!!
OZRacing is offline   Reply With Quote
Old 09-14-2003, 06:37 PM   #7
coolio, thanx
Old 09-14-2003, 06:38 PM   #8
for a proper reading, do what B said, wideband O2 seperate from the other o2 sensors..
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 09-14-2003, 06:48 PM   #9
You still be able to read off of it even is its not wideband.... I got a BOSH O2 sensor, and it reads fine. I can see difference between fuel pressures...
The only way you are going to read something out of it is at WOT... The grounding to the batt part is the most important thing to get good readings off of a A/F gauge..
YOU'RE ALL GAY!!!
Old 09-14-2003, 08:37 PM   #10
RETIRED
it READS fine, but its a bullshit reading.
read this: http://www.hondata.com/techwidebandtuning.html
it might be "close" but it really only tells you two things- lean, or rich. thats it. the voltage a 4-wire non-wideband o2 sends out has very little difference in voltages to send back to the gauge.
a wideband on the other hand actually changes voltage.
Old 09-14-2003, 11:59 PM   #11
ok well i got it installed and it workks, i guess. Umm yea i dont really personally know if it works, but it lights up and every thing. OK so yea, the gauge is constantly reading RICH, at idle, higher rps, and at acceleration. on deceleration, it reads Super Lean. Is this normal for a honda?!? It just doenst seem riht to me.
Old 09-15-2003, 03:04 AM   #12
RETIRED
its a light show. enjoy it.
Old 09-15-2003, 03:42 AM   #13
Rep Power: 30 SolReaver is off the scale
its fine.
<a href=\'http://www.FreeiPodShuffle.com/default.aspx?r=15723497\' target=\'_blank\'>Get a free ipod shuffle, Yes it works! </a>
I will paypal $8 to the first 3 people to complete the offer, PM me if interested.
SolReaver is offline   Reply With Quote
Old 09-15-2003, 01:10 PM   #14
exactly what I was going to say, It's like a Pointless reading...why have it if it doesn't work properly but good to hear you got it running.
I still recommend the wideband like B said
Old 09-15-2003, 04:38 PM   #15
How much do the wide band o2 sensors go for... and yes i plan on installing 2 of them soon, in place of my stock sensors. Are there any that fit my Header so that i wont have to install any sort os thingy ma-bobs? I read Ludespeend.com's article about them, and he said after installing them he got batter gas millage, and a better overall running car too. About how much do these run for. I got an autozone, here. HOw much am i looking to spend? and from what year kinda car should i get them from?
Old 09-15-2003, 08:07 PM   #16
RETIRED
they are far from cheap. but moreover, your stock honda computer won't work with it. you are better off just getting another bung welded in right next to your other o2.
expect about 500-1000 for the sensor and reading instrumentation, and for it to last 20k miles at best.
Quicker ratio steering rack for EG? stmotorsports Wheels / Suspension / Tires / Brakes 6 06-04-2004 11:53 AM
compression ratio??? scottp11 General Tech and Maintenance 6 05-28-2004 03:06 AM
Automotive Formulas pissedoffsol Reference Materials 0 03-01-2004 07:06 AM
How to Compute the Compression Ratio of a motor pissedoffsol General Tech Articles 0 01-12-2004 01:41 AM
Air/fuel Meter Vs Egt Meter JDMSpecAccordSir-T Forced Induction 5 06-19-2003 02:11 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
