2265787829
Ride: Refer to my name, dumbass.
00 Si, stock b16a2.
tonight i went to get some food, on the way back I was just fuckin around and revved to 5k and shifted. i started noticing this really, really faint whistling sound that started around 4500 rpm and continued until 5500 rpm. I couldn't hear it after vtec engaged, but i'm betting it keeps on going. it's about 28 degrees outside, and i just had my belts (serpentine and timing) changed just 3000 miles ago. what could it be? |
2265787829
The PS, AC, alternator belt. the dealer called it a serpentine belt... whatever it is.
anyway, i thought valves ticked when they were getting worn? [img]style_emoticons/<#EMO_DIR#>/unsure.gif[/img] |
#5 |
HS Troll...And Mod
Ride: 2001 Honda S2000
door seal does sound like a good theory.
i had a T3-60 sound in my engine bay for a while. Turns out it was a blown exhaust gasket. __________________
If you PM me with tech questions, you better have a link to the thread in your PM. Anime Informant |
#8 |
2265787829
<div class='quotetop'>QUOTE(civic92jak @ Jan 7 2006, 12:24 AM) Quoted post</div><div class='quotemain'>
I'd check the exhaust manifold if you have the stock one. But if you don't, i'd check it anyway. My bro's accord manifold cracked and made that exact sound. [/b][/quote] oh cool. it'll give me an excuse to put my header on asap. |
#9 |
mine does that but it's only at certain levels of holding down the throttle. my guess on that was somewhere with the throttle body... or something. dunno, bro.
<span style=\"font-family:Tahoma\"><span style=\"font-size:10pt;line-height:100%\"><span style=\"color:black\">..::Bl<span style=\"color:red\">a</span><span style=\"color:black\">ck Wi</span><span style=\"color:red\">d</span><span style=\"color:black\">ow g</span><span style=\"color:red\">2</span><span style=\"color:black\">::..</span> <span style=\"color:gray\">swapped~&~ dropped 90 integra LS ~ B16A</span></span></span></span> <span style=\"color:gray\"><span style=\"font-size:10pt;line-height:100%\">··¤(`×[¤<span style=\"color:red\"><span style=\"font-family:Tahoma\">if you don't like oral sex, shut your mouth!<span style=\"color:gray\">¤]×´)¤··</span></span></span></span></span> |
#10 |
RETIRED
WOOOO WOOOOOOOOOOOOOOOO!!!!!!
You got a whistle tip y0!!!!!!!!!!!!!!!!!!!!!!! :bubbrub: lol check for a tiny leak around your air filter cone. it will whistle if air is getting sucked in on the rubber at the end of the filter. |
