Final Drive
Old 01-17-2003, 03:42 PM   #1
92CivicCx's Avatar
Rep Power: 66 92CivicCx is on a distinguished road
Send a message via AIM to 92CivicCx Send a message via MSN to 92CivicCx
i was lookin at the gearing for the 5th gen civics and i found out the gearing the same but the final drive is different.... so what my question is what is final drive and what final drive is better.
i found this info here in reference
this goes for cx/dx/si
1st: 3.25
2nd: 1.9
3rd: 1.25
4th: .909
5th: .702
cx final drive : 3.888
dx final drive 4.058
si final drive 4.25
current cars
1996 accord ex, new dd
2000 Plymouth Voyager, wifes whip
www.fivezeroseven.com
92CivicCx is offline   Reply With Quote
Old 01-17-2003, 06:29 PM   #2
Slammed89Integra's Avatar
Ride:  2007 Scion TC, 2005 Suzuki GSX-R 600
Rep Power: 155 Slammed89Integra has a reputation beyond repute
Slammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond repute
Send a message via AIM to Slammed89Integra myspace
Hey I am not quite sure, but I believe it is the gear between the actual 1st 2nd and 3rd thust making many longer and what not. don't take my answer for sure because really I have no clue but play gran turismo 3 a lot. Someone else correct me if I am wrong.
When this is all over I think we should get an apartment together.
Slammed89Integra is offline   Reply With Quote
Old 01-18-2003, 04:44 AM   #3
Rep Power: 17 chevy302dz is off the scale
What you are seeing is due to the gearing in the differential. After power goes through the transmission gears but before it goes to the wheels it has to travel through the differential which has a ring and pinion gear in it. This gear can vary in ratio anywhere from 2.5 to 6.5 to 1 and it acts as a muiltiper for the gears in the tranny. As for what's better the higher the number the quicker you will get to speed, but a lower number number means you can achieve a higher top speed, so what's better depends on your app but generally you want to stick to the high side Aka a shorter gear. Hope this helps
</span><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE (Pissedoffsol @ Posted: Apr 15 2003, 12:35 AM)</td></tr><tr><td id=\'QUOTE\'>killing a saturn is like beating off and calling it sex</td></tr></table><span class=\'signature\'>
chevy302dz is offline   Reply With Quote
B-series Transmission Guide pissedoffsol Swap Articles 1 06-01-2004 05:46 PM
Type r final drive? korey Engine Building 9 03-10-2004 06:03 AM
B-series Tranny Speed VS. MPH pissedoffsol Reference Materials 0 01-06-2004 10:52 AM
Final Drive & Turbo Setup hondasingapore Forced Induction 4 05-08-2003 05:24 AM
B18c5 In 88 Crxdx Will There Be Room 4 Turbo?>? T4 88crxdx HYBRID -> EG-EK / DC 13 02-04-2003 05:03 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
