Ride: 93 del Sol Gas sipper
What fuel filter should I buy for my sol. As of know my car is running a little rich and getting bad MPG. My engine mod list is still very basic. What brand should I get? OEM, .....
Collin Material Science and Engineering Michigan Technological University |
Go with oem, there are others out there (I think holley, but not sure) but oem is best IMHO
Milan __________________
#6 |
go with oem, don't waste your cash on some other so called "high flow" BS from AEM, i dont' give two fucks what someone tells you on this board........high flow doesn't mean shit to me.....
#7 |
If a engine is running rich why would you feed it more fuel?
I'd go for a full tune up using OEM or equivlent parts and check the o2 sensor.__________________
</span><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE (Pissedoffsol @ Posted: Apr 15 2003, 12:35 AM)</td></tr><tr><td id=\'QUOTE\'>killing a saturn is like beating off and calling it sex</td></tr></table><span class=\'signature\'> |
#8 |
Have you checked your: Plugs, Spark Plugs (Proper gap and burn), Ignition Wires, Cap, Rotor and even tire pressure. These are all regular maint things to check for this rich condition you are having.
![]() __________________
Mr B |
#9 |
O2's burn out frome time to time.
#10 | |
#11 |
Ride: 88 Honda Civic HB
you dont need a high flow fuel filter if you dont have a high flow fuel pump and a engine that doesnt need a high amount of fuel.
#12 | |
Banned
didnt see that you were running a lil rich. thought u were just looking for a high performance filter. i know u checked/replaced all your plugs and stuff before in that other thread, so if the new cap and rotor didnt help, i would suggest getting your fuel injectors cleaned at a shop. they jet some cleaner through them. maybe thats what it needs. i know youve already tried using lots of off the shelf f.inj. cleaner, but i think the pressure cleaning that a shop does is more effective. |
| Drag kit install manual | pissedoffsol | Forced Induction | 0 | 07-18-2004 12:37 AM |
| Fuel system | Sed8ed | Engine Building | 2 | 05-26-2004 01:05 PM |
| Fuel filter | nachogj | General Tech and Maintenance | 8 | 10-20-2003 07:00 PM |
| changing fuel filter on crx | GSRCRXsi | General Tech and Maintenance | 4 | 09-20-2003 09:08 PM |
| High Flow Fuel Filter? Injectors Clogged? | importimage | General Tech and Maintenance | 0 | 05-17-2003 03:56 PM |
