Fuel Pressure: PSI
Old 10-13-2009, 04:51 PM   #1
mynumber1hater's Avatar
Rep Power: 1 mynumber1hater is on a distinguished road
Default Fuel Pressure: PSI
My set up: 92 tegg
B18c1 bottom end
GSR crank and rods
CTR .25 over pistons (PCT)
ARP head studs
ITR water pump
B16A oil pump
NEW tensioner
DC sports 4-1 header
Head:
B16A head, ported and polished, 5 angle valve job
ITR cams
ITR valve springs and retainers
ITR injectors
B16 intake
What fuel pressure (PSI) should i be running? The car is running a little rich.
mynumber1hater is offline   Reply With Quote
Old 10-13-2009, 04:58 PM   #2
Runnin' on a chipped Mugen P28, after market Adj FPR.
Old 10-13-2009, 05:19 PM   #3
B
Administrator
B's Avatar
Ride:  318ti, dakota, genesis 2.0t
Rep Power: 403 B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
myspace  FaceBook
the "mugen" chip is your problem. leave your fuel pressure alone...
get the car tuned with a map FOR your car, not a 14:1, 11k rpm mugen race car.
Originally Posted by Airjockie View Post
I got plenty of duck tape, but no penguin tape...
B is online now   Reply With Quote
Old 10-13-2009, 05:19 PM   #4
mdpsEG's Avatar
Ride:  JRSC B20/vtec DC, Nissan Xterra SE
Rep Power: 43 mdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant future
you are running rich because of your chipped ECU not fuel pressure. with the type of modifications you have listed there is no way the car will run 100% with any type of basemap "chip". you need to have the car tuned. either do some research on your own or find someone in your area that can tune and they will tell you what you need to do. there are many options, but a lot of tuners may only work with one or two tuning programs.
to my knowledge, ITR injectors are the same 240cc ones used on other b series. you should probably just run the stock fuel pressure.
mdpsEG is offline   Reply With Quote
Old 10-13-2009, 06:06 PM   #5
I am the second owner and im trying to work out the bugs.. I was told it was tuned when i bought it ... What is the stock fuel pressure?
Old 10-13-2009, 07:38 PM   #6
F.I. Junkie
Ride:  1996 Civic, 1992 Accord
Rep Power: 101 Matts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Send a message via MSN to Matts96HB
Tuned means a map specifically for that car and that setup.
IMO, a car is not "tuned" until there's a wideband in the car and the readings are where they should be.
You need to look into alternate methods of tuning. Guesswork will only yield damage in the end.
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6-
Matts96HB is offline   Reply With Quote
Old 10-15-2009, 07:56 PM   #7
B
Administrator
B's Avatar
myspace  FaceBook
stock fuel pressure is around 42-45psi.
Old 10-19-2009, 03:53 PM   #8
You guys where right.. FP just fine. I called a few places to get it tuned and they want 450. Thats too much. What can i do? ARe there places a can send the P28 and have it re-chipped or can i just buy a stcok chip and run it for a while??? I dont need the car to put out every last HP it has. thanks
Old 10-19-2009, 04:26 PM   #9
B
Administrator
B's Avatar
myspace  FaceBook
the only way to be SAFE is to have it custom tuned.
where are you located? perhaps theres a guy local who can help who's not a shop and won't charge you an arm or a leg
Old 10-19-2009, 04:39 PM   #10
houston tx
Aem fuel rail with aem fuel pressure regulator b-series RSS-Bot Auctions 0 02-09-2009 02:36 PM
AEM fuel rail and adjustable fuel pressure regulator RSS-Bot Auctions 0 04-24-2008 07:03 PM
Fuel Rail and Fuel Pressure Regulator Help raidmax General Tech and Maintenance 9 02-04-2007 02:45 AM
no fuel pressure, fuel pump wont turn on gilronaldo ECU's, Electronics, and Tuning 2 11-21-2006 03:57 PM
OBD2-1, P28, Hondata S100, Fuel Pressure,Fuel Pump khai_tuan_nguyen Parts: For Sale/Trade/Wanted 6 01-20-2004 03:47 PM
