Fuel Pressure Question
Old 09-24-2003, 10:01 PM   #1
Rep Power: 0 dhondagini is off the scale
Heres the deal.
I recently swapped a b16asir2 into a 93 civic.
I was planning on forced induction, but time ran out before college, adn now so has the $.
This was a swap into a car that was also being completely redone and ofcourse little things kept comming up in the end, such as the fuel pump going.
I had installed a Aerospeed Fuel regulator and gauge (the kind that modifies the stock unit, not a whole new one)
When the pump went, I thought, why not just get a walbro 255, so I did. well, now the fuel pressure is like 53psi and flames are comming out of the exhaust.
As cool as that may be, I know I cannot run this.
-The fuel regulator won't go down any lower and we even swapped a stock regulator and that only gets it to 50 psi.
-I also have a Apexi Vafc
My question is, how can I get the psi down in a cost effective way. Will the vafc change this drastic ratio, is there a better regulator I can get that will actually decrease the psi or should I get a different fuel pump, if so which one?
Also if getting a stock fuel pump is the key, I will swap anyone who has a stock pump with reasonable miles on it for free as long as the person pays for shipping both ways. My pump has like 30 miles on it.
dhondagini is offline   Reply With Quote
Old 09-24-2003, 10:03 PM   #2
Rep Power: 29 rudeludenotmeanthough is off the scale
isnt stock fuel pressure 40 psi?
</div><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE (94RedSiGal @ Dec 2 2003 @ 12:27 AM)</td></tr><tr><td id=\'QUOTE\'>Having a ClubSi, Honda-Tech or HondaSwap sticker on them would just scream &quot;Steal Me Now! I'm a special car!&quot; to thieves.</td></tr></table><div class=\'signature\'>
rudeludenotmeanthough is offline   Reply With Quote
Old 09-25-2003, 01:22 AM   #3
tab
Ride:  03 Avalanche
Rep Power: 51 tab is on a distinguished road
Send a message via MSN to tab
Well, you could install a pressure reduction valve, an adjustable regulator, a pressure switch to turn off your pump, replace your pump with a less efficient one.
I thought that your pump should turn off at a specified pressure. Otherwise the same thing would happen at an idle in every Honda(too much pressure), unless Honda makes a pump that won't build enough pressure to cause that.
Be careful not to confuse volume with pressure. You want a high volume of fuel when your car needs it, but supplying 150 psi through a pinhole won't do it. I'm sure you know that but many people don't.
It is a possibility that your old pump wasn't turning off soon enough and burned itself up. Consequently, if you added a new pump it would do the same thing until you find the culprit. Just a thought.
2003 Chevy Avalanche
Leather, Moonroof, Z71, tow package, bose+six disc, nice.
1992 Accord EX (sold to good friends)
JDM H22A
H22A Auto Tranny w/LSD
I/H/E -- All stainless w/2.5 inch Catback
1968 Oldsmobile Toronado
Project car, 455 ci front wheel drive, nasty.
Old 09-25-2003, 09:43 PM   #4
- I have the adjustable regulator, but it won'd adjust any lower than 53.
-Where can I find a pressure reduction valve? what exactly does it do?
-The pressure switch, is that a relay near the fusebox or something that may be bad? is this something I can buy incase the pump isn't turning off, where can I get a good one?
I am trying not to have to get a new pump because a honda pump is like $170 - $200 and I just bought the walbro and would like to keep it, the buying a new pump would be a lst resort.
thanks
Old 09-25-2003, 10:15 PM   #5
Rep Power: 30 SolReaver is off the scale
What do you mean "a pressure reduction valve?"
What would be the purpose of a pressure switch to turn off the pump?
Fuel pumps dont keep pumping higher and higher pressures when they are receiving voltage- They are either on or off, and when they are on thats as much fuel as they will pump without increasing the voltage
The fuel pressure regulator allows for this, when you open the throttle the diaphraghm closes and increases the pressure..it lowers the pressure at idle
Once again- If the fuel pump was turning off when the motor is running, it would shut off due to lack of fuel.
highly unnecessary, as the pressure can be modified quite easily at the fuel rail
check out endyns site for a how to on drilling the stock fpr diaphragm to lower pressure by sending more fuel back to teh tank
<a href=\'http://www.FreeiPodShuffle.com/default.aspx?r=15723497\' target=\'_blank\'>Get a free ipod shuffle, Yes it works! </a>
I will paypal $8 to the first 3 people to complete the offer, PM me if interested.
SolReaver is offline   Reply With Quote
Old 09-25-2003, 11:29 PM   #6
tab
Ride:  03 Avalanche
Explanation.
I work at my local water dept. We have very powerful pump stations in places that make so much pressure that they will literally blow the plumbing apart inside the walls of a house. Many of those people with inferior plumbing use pressure reduction valves. I won't pretend to know how they work, but they do work. Much like a regulator it sounds like. I searched summitracing.com before my post, and they have them for fords and stuff. I just placed it out there as an option.
To keep a system at full pressure, it is not necessary to make the pump run all the time. Stored Kinetic Energy I believe is the term. If the pressure were to drop to a certain point, the pump could come back on to preserve the set pressure. I didn't know that Honda pumps stayed running all the time, or that they bypassed through the regulator back to the tank.
So you're suggestion is to make the return line larger in order to allow the system to run at a lower pressure. Wish I would have known that before my post.
JDM H22A
Old 09-26-2003, 12:18 AM   #7
Rep Power: 59 hcivic.com is on a distinguished road
not true pumps will pump more fuel as you add voltage up to the 15.4 volt mark where most pumps crap out on newer vehicles pumps are called rising rate where the fuel pressure is controlled by changing voltage
hcivic.com is offline   Reply With Quote
Old 09-26-2003, 12:20 AM   #8
B16
B16's Avatar
get a better fpr, the aem one is pretty nice
2004 BMW 325i
2000 Mercedes Benz ML 430
Old 09-26-2003, 03:28 AM   #9
Rep Power: 17 noobvang is off the scale
Need fpr that will not use part of stock unit. i.e AEM fpr.
OR
get the 190 lpg fuel pump.
96 LX 4dr. with B18a, PR3 pistons, B16 head w/ port 'n polish to intake, CTR intake/exhaust cams, ITR IM, CTR TB, Hondata IM gasket, RC 310cc injectors, Denso Iridum plugs, Skunk2 valve springs/retainers, Excedy race clutch, ACT streetlight flywheel, Walbro 255 fuel pump, GSR tranny, and Tanabe Super Racing Medalion...., next is Header and VAFC.
Best run on 1320:
14.5 @ 94.5mph street tires
14.4 @ 94mph small slicks :P
98 Yamaha R1
noobvang is offline   Reply With Quote
Drag kit install manual pissedoffsol Forced Induction 0 07-18-2004 12:37 AM
Fuel system Sed8ed Engine Building 2 05-26-2004 01:05 PM
Fuel Pressure Regulator Failure luVTEC General Tech and Maintenance 2 05-27-2003 09:06 PM
"q" On Fuel Pressure Gauge And Headers. 1.8ek General Tech and Maintenance 3 04-06-2003 02:22 PM
Fuel Pressure? uhh45 Forced Induction 1 01-30-2003 01:23 AM
