Fuel Pressure Regulator Failure
Old 05-27-2003, 06:02 PM   #1
luVTEC is off the scale
I have been having some fuel related problems with my CRX and I suspect its my fuel pressure regulator. My question is what are some symptoms of a bad FPR? anybody ever had one fail?
see below for full description...
If your interested I'll bring you up to speed on whats happended. My CRX had been having problems starting until one day it just died. I noticed that there was no smell of gas when I cranked it over b/c I had the intake off. I disconnected the fuel line at the filter (from the pump) and shure enough...no gas would come out when I cranked it. <_<
I figured it was either a bad fuel relay or pump (the pump was replaced only two yrs ago). I tested the relay and the relay harness first, it checked out. I removed the fuel pump and tested it, it worked fine. I blew air through the fuel lines to see if they were blocked, nope they were fine. I put everthing back together and it worked , not knowing what it was I replaced the fuel relay anyway <_< .
It worked fine for a day then it began to loose power under load. The CEL came on and it threw a CODE 1 O2 sensor? Now it won't star at all? the fuel pump won't pump when the key is truned? WTF? I got a new fuel filter too. The only original parts of the fuel sytem left are the injectors and the pressure regulator, so I suspect the regulator.
please help if you know thanks.
underpowered 93 Civic DX
luVTEC is offline   Reply With Quote
Old 05-27-2003, 06:27 PM   #2
kingwilly is off the scale
check your grounds..sounds to like an electrical problem..check all connections too
kingwilly is offline   Reply With Quote
Old 05-27-2003, 08:06 PM   #3
oh yeah, I forgot to mention i went through all the grounds for the engine and fuel system, they looked clean , but I cleaned them up anyway.
thanks for the reply though
Drag kit install manual pissedoffsol Forced Induction 0 07-17-2004 11:37 PM
Fuel system Sed8ed Engine Building 2 05-26-2004 12:05 PM
Fuel Pressure Question dhondagini General Tech and Maintenance 8 09-26-2003 02:28 AM
"q" On Fuel Pressure Gauge And Headers. 1.8ek General Tech and Maintenance 3 04-06-2003 01:22 PM
Fuel Pressure? uhh45 Forced Induction 1 01-30-2003 12:23 AM
