fuel pump or main relay
Old 08-14-2005, 10:08 PM   #1
Rep Power: 15 b16coupe is off the scale
Send a message via AIM to b16coupe
A friend of mine's 94 accord isn't getting fuel. I just want to know if it is the main relay or fuel pump. If the main relay was bad it wouldnt click at all would it? If it does click but i dont here the fuel pump then it would be the fuel pump right? Is there anything else i could check for or measure with a voltmeter to see if it was the fuel pump?
thanks
93 civic ex
b16a sirII
Y21 w/lsd
205/40/16 nitto neo gens (better than nt450's)
Exedy Clutch
ctr pistons
no more turbo...stupid ring lands
b16coupe is offline   Reply With Quote
Old 08-14-2005, 10:16 PM   #2
Rep Power: 19 CiViC_SOHC is off the scale
Send a message via AIM to CiViC_SOHC
get a fuel pressure tester...put it on top of the fuel filter under the hood...thats bout your best bet....if it doesn't start sometimes like stalls when you just got out of the car or something...then its probably your main relay
1992 EG8 Civic Sedan / '98 D16Y7 swapping a D16Z6...TURBO!
Support the local Performance shop. <a href=\"http://aeiperformance.com/\" target=\"_blank\">AEI performance</a>
CiViC_SOHC is offline   Reply With Quote
Old 08-14-2005, 10:23 PM   #3
well, i know that there ins't any fuel pressure. If the main relay's solders had craked then it wouldn't click at all would it?
93 civic ex
b16a sirII
Y21 w/lsd
Exedy Clutch
ctr pistons
Old 08-14-2005, 10:49 PM   #4
Rep Power: 29 VTECPOWER is off the scale
Send a message via AIM to VTECPOWER
If the solder's are cracked then the ecu and fuel pump arent getting power, you can try to solder the main relay if you are good enough or find someone to do it.
DB8 450whp project......
VTECPOWER is offline   Reply With Quote
Old 03-18-2009, 10:42 PM   #5
Greenhorn
Ride:  honda del sol
Rep Power: 0 tijuanillo is on a distinguished road
i also have the same problem on my honda del sol but the main relay its not crack and it will click so is it the fuel pump???
tijuanillo is offline   Reply With Quote
