Fuel pump probs (I think)
Old 06-27-2006, 06:53 PM   #1
Rep Power: 0 krut042303 is off the scale
Default Fuel pump probs (I think)
Alright, I've got a 90 Crx with a B16a3, P30 ecu, walbro 255 fuel pump and almost half the time (usually when the engine is still warm) I start the engine and it starts and then just dies even when I give it gas its like I'm not even stepping on it. Then I turn off the key and turn it back on and the fuel pump doesn't make any noise so it doesn't even charge the fuel rail and it won't start at all. So I wait a couple of minutes turn the key, fuel pump will pump but when I start it I have to take it up to like 4000rpm right off the bat and keep it there for about 30 seconds or until everyone at the gas station is giving me looks and then its fine until i turn the key off. Its never died while running, only right after i start it. Any ideas? Thanks
krut042303 is offline   Reply With Quote
Old 06-28-2006, 10:18 AM   #2
BORICUAFLAVA2's Avatar
Rep Power: 0 BORICUAFLAVA2 is an unknown quantity at this point
have you tried installing a relay direct from the ignition, instead of the factory main relay. it might be that since you have a higher pumping fuel pump and it might need a higher voltage going to it.
BORICUAFLAVA2 is offline   Reply With Quote
2000 SI Fuel Pump Problem tuppscivic ECU's, Electronics, and Tuning 3 08-24-2005 03:44 AM
fuel pump mozzandherb General Tech and Maintenance 5 06-26-2005 04:30 PM
Ls swap...Fuel pump or fuel filter Questions. CRXSI91 HYBRID -> ED-EF / DA 5 06-15-2005 05:32 PM
Drag kit install manual pissedoffsol Forced Induction 0 07-18-2004 12:37 AM
Fuel Pump? drewdrew HYBRID -> EG-EK / DC 14 02-20-2003 11:02 PM
