gs-r raises compression?
Old 08-24-2004, 01:40 PM   #1
allmotorbeasteg6 is off the scale
rite now i have a b20 with a compression of 12:0:1 with a b16a head, but if take off the b16a head and put on a gs-r head, will the compression go up? if so how higher will it go up? also can i get a thicker head gasker to lower the compression?
allmotorbeasteg6 is offline   Reply With Quote
Old 08-24-2004, 01:54 PM   #2
Member of the 20 nut club
E_SolSi's Avatar
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
yes a GSR head will slightly raise the CR
it only raises it about 0.2:1 not a very cost effective way of raising compression IMO
and yes you can get a thicker gasket to lower the compression
you could also get a thinner gasket to raise it
Old 08-25-2004, 09:39 AM   #3
GSRCRXsi's Avatar
GSRCRXsi is a splendid one to beholdGSRCRXsi is a splendid one to beholdGSRCRXsi is a splendid one to beholdGSRCRXsi is a splendid one to beholdGSRCRXsi is a splendid one to beholdGSRCRXsi is a splendid one to behold
what pistons are you running to get 12:1?
