Head Gasket replacement on D16A6
Old 09-20-2005, 10:38 PM   #1
Rep Power: 14 Civic_Tacoma is off the scale
Send a message via AIM to Civic_Tacoma
I'm having some oil issuses with my D16A6 engine. It looks like it's leaking from around the head gasket, and the water pump gasket. I know that if I change the head gasket, that I should go ahead and change out the water pump, water pump gasket, and the timing belt also. My question is, what else should I go ahead and change? Does anyone make head studs (bolts) for this engine? Thanks in advance, looking to do this in the next few weeks.
Civic_Tacoma is offline   Reply With Quote
Old 09-20-2005, 11:07 PM   #2
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
Rep Power: 384 phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
ARP makes studs for the d series.
If its leaking, fix it.
If the timing belt is showing signs of wear, change it.
[/mr.obvious]
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
Old 09-17-2007, 10:34 PM   #3
Ride:  black 91CRXsi 1.6
Rep Power: 0 ladyowned is on a distinguished road
myspace
Smile 91 crx head gasket leak
Hello, we have changed my head-gasket too because we had the "leak". I ordered the "special" gasket and new bolts as recommended in the service bulletin and have had sputtering troubles ever since. We can't get the timing to go right, it's too far or not far enough! My husband thinks that after plaining the head and putting a different size gasket has thrown all out of whack.
Thanks for any help......
http://www.engine-builder.com/ar/Import.pdf
ladyowned is offline   Reply With Quote
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
