Facebook Twitter
Help Its Bleading
This is a discussion on Help Its Bleading in the General Tech and Maintenance forum
i have a 97 d16y7 it is a manual with 100k on it it is leaking oil from either the main seal next to the trans or the pan. Is there a comon place on these engines that leak and is there a way to ...
Old 03-23-2003, 09:45 PM   #1
i have a 97 d16y7 it is a manual with 100k on it it is leaking oil from either the main seal next to the trans or the pan. Is there a comon place on these engines that leak and is there a way to trace it down? Also the brace or somethink of that nature on the bottom below the fly wheel bolted to the block and to the bellhousing it has 4 bolts in it 2 12mm and 2 14mm can this be removed to take the pan off and change the pan gasket or se if the leak can be detected by eye thanks any help would be great
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
97hatch is offline   Reply With Quote
© 2001-2013 HondaSwap.com
