High Flow Fuel Filter? Injectors Clogged?
Old 05-17-2003, 03:56 PM   #1
Rep Power: 15 importimage is off the scale
I have a 1993 honda civic oem fuel filter right now. I have a CR/VTEC Turbo swap and am making 325 HP at the front wheels.
Once I hit 6500 rpm recently, my car sets a code 16 (Fuel injectors). I have a set of 550 RC injectors. I have probably put 10000 KM on the car. Do you think that this code is coming up because the injectors are clogged????? When I got the injectors, they were used from another dudes car becaues he upgrade to 660 injectors. If so, should I send them to RC for cleaning or is there another alternative???
OR
Do you think it could be the fact that I am using a OEM pinner fuel filter????
OR
Do you think that I should upgrade the fuel lines??? If this is the case, what size and what material should I use????? I was reading a honda tuning magazine and they said to only do this if you are at 400 HP. Not too sure if that meant at the wheels....maybe I am boderline right now?????
Please help
Mr B
importimage is offline   Reply With Quote
Drag kit install manual pissedoffsol Forced Induction 0 07-18-2004 12:37 AM
research paper, what do you think? 90 accord Members' Lounge 9 06-23-2004 12:11 AM
fuel injectors darwins_vtech General Tech and Maintenance 2 01-16-2004 07:06 AM
About changing fuel injectors HondaScythe General Tech and Maintenance 2 10-20-2003 12:13 AM
changing fuel filter on crx GSRCRXsi General Tech and Maintenance 4 09-20-2003 09:08 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
