High Idle Than Bam Irratic Idle
Old 10-27-2003, 12:05 AM   #1
Rep Power: 24 Accordturbo94 is off the scale
Hey Ive had my h22 swapped in my car for a couple months now and out of the blue the other day, my car begain to idel high. About 1200-1300.. Than out of the blue it started the high idle to the irratic idle! I cant figure it out.. Ive checked for vac leaks. There was none.. I checked the TPS for voltage off my vafc.. .568ish closed and 4.?? at wide open. I tryed adjusting the idle on the throttle body.. its all the way closed and the revs still wont come down. Ive also checked the Idle Air Control Valve.. i disconnected it and the idle went down a bit.. but still the up and down revs. Im lost.. oh and Ive checked the timing.. thats great too. And I dont hear any leakes off the throttle body.. plus its a new gasket there..
I thought I would be as detailed as possible with this to help out. sorry its so lengthy. Its just hard to believe I got it to run great before.. and now its POO
Accordturbo94 is offline   Reply With Quote
Old 10-27-2003, 10:24 AM   #2
Old 10-27-2003, 08:51 PM   #3
yeah when i start my car in the morning or after work it revs high untill it warms up than it begins to go up and down!
Old 10-27-2003, 08:59 PM   #4
Rep Power: 13 03jetta1.8t is off the scale
egr valve, probably sticks, and when it warms up the seal starts to flap up and down, most likely, engine light at all
03jetta1.8t is offline   Reply With Quote
Old 10-27-2003, 09:10 PM   #5
Rep Power: 25 MXDesa will become famous soon enoughMXDesa will become famous soon enough
Send a message via AIM to MXDesa
Idle air motor. Right behind the intake manifold. Looks like a big solenoid. Change it with a new one. Trust me, i've encountered 3 honda motors with the same problem. Idle air motor every time.
2003 EP3 Civic SI - Pretty Much Stock (for now)
1990 Eagle Talon TSI Turbo AWD
2005 Kawasaki ZX-6R - 10.58 ET at 137 MPH
MXDesa is offline   Reply With Quote
Old 10-27-2003, 09:27 PM   #6
thats on the f22! I have it on the front of the intake manifold! Im going to try to take it off and see if theres carbon in it! Is it possible that all of a sudden they will just go to poo! this thing ran awesome before!!! no codes just my vtec oil psi
Old 10-27-2003, 09:28 PM   #7
the egr is not hooked up! if i remember right it gets blocked by my hondata intake manifold gasket! it has never been hooked up and when its not the car runs better!
Old 10-27-2003, 09:42 PM   #8
Ride:  '94 DX hatch
Rep Power: 21 ahedau is off the scale
Send a message via Yahoo to ahedau
I talked to a family friend that's the service mgr for a local Honda dealer. He says its the IAC...not only 'cause of the irratic idle but because it changes once the car warms up. He said the shop fixes it by pulling the IAC and spraying carb cleaner in them to get rid of the carbon buildup. If the engine was sitting for any period of time before the swap that also could contribute to the problem of the IAC sticking causing you your headache.
Other than the IAC, remove the TPS and coat it in WD-40 and make sure there is no buildup there. Then put it all back together and everything should be okay.
ahedau is offline   Reply With Quote
Old 10-27-2003, 10:22 PM   #9
yeah i just took that beast off and blew it out with an air gun.. I didnt see this post in time to try wd40 but just blowing it off did not help! I took off the connector and than the idle dropped but it still just barely the idle went up and down.. So i just cant figure this thing out! I know my car is runnin real rich sut it coming out the exhaust and stains my damn floors but im thinkin its doing it because of the c.e.l. But thats another thing. I just want my car the way it ran 3 days ago! PERFECT
Old 10-28-2003, 10:33 AM   #10
anyone else got a theory
Old 10-28-2003, 07:04 PM   #11
Rep Power: 29 rudeludenotmeanthough is off the scale
vaccum leak.... the leading cause of all Honda idle headaches...
But really, check them.
</div><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE (94RedSiGal @ Dec 2 2003 @ 12:27 AM)</td></tr><tr><td id=\'QUOTE\'>Having a ClubSi, Honda-Tech or HondaSwap sticker on them would just scream &quot;Steal Me Now! I'm a special car!&quot; to thieves.</td></tr></table><div class=\'signature\'>
rudeludenotmeanthough is offline   Reply With Quote
Old 10-28-2003, 07:17 PM   #12
Location: originally: Napa, CA now: Phoeniz, AZ (for school)
Rep Power: 13 9k RPM EG6 is off the scale
Send a message via AIM to 9k RPM EG6
wrong gasket on the throttle body. they gave you the wrong gasket, it's blocking the warm start passages.
That or your EGR valve is going wacky (but do Preludes run EGR?). Voltage is normal at TPS, should be like 4.7 at WOT. check the gasket, I'm 99% sure you either installed it backwards or it broke or it's wrong.
Good luck bro!!!
-B
1992 &quot;VX&quot; (EG6) hatchback
1992 JDM B16A (P30 ECU by Mugen)
1996 CTR S4C LSD trans (4.4 final)
Skunk II/Tokico 5 way adjustables
C/F hood, Spoon Duckbill, JDM corners
much, much more...
Best Pass is: 13.72@101
9k RPM EG6 is offline   Reply With Quote
Old 10-28-2003, 07:22 PM   #13
you know, after reading more carefully, it MAY be the IAC. Normally though, the stepper motor begins sticking, so it'll grow worse progressively. If you disconnect it and it changes, it probably has nothing to do with the problem. Your stepper motor in the IAC only works so fast...so if you disconnect and it changes idle, but not a whole lot, prolly not the IAC. Change the Throttle Body Gasket. Otherwise get a "known good" IAC and see if it solves the problem.
I doubt your EGR is even connected. And yes, car should run MUCH better. Besides, EGR causes PISSED OFF IDLE, not irratic. Gasket or IAC.
-B
much, much more...
Old 10-28-2003, 07:37 PM   #14
This is no theory about it. Whether the IAC is on the back or front, thats is the problem. Sorry about my mistake saying it was on the back. But change it with a good known one and it should solve the problem. Good Luck
Old 10-28-2003, 08:00 PM   #15
gotta love them "known good" parts....
-B
much, much more...
Old 10-28-2003, 11:46 PM   #16
New gasket in the throttle body.. you know when those are bad, you can hear it a mile away!!! when i disconnect my IAC the idle comes down from the 1300-2500 bounce to like 12-1300. and yes it still bounces just a bit. The vaccum lines are great ive checked them many times and have put soap on them to check for bubbles... nadda! like i said one day my car just started to rev to about 1200.. didnt think much of it cause it wasnt to bad.. now as soon as i get in it to drive and its been sitting it revs to like 2900 till it warms up! vs the normal 1500 rpms it used to be like! than as soon as its warm it revs up and down from like 1300-2000 or so.. im not exacly sure how high it goes now! AHH this sucks
Old 10-28-2003, 11:48 PM   #17
Originally posted by MXDesa+Oct 28 2003, 07:37 PM--><div class='quotetop'>QUOTE(MXDesa @ Oct 28 2003, 07:37 PM)</div><div class='quotemain'> <!--QuoteBegin-Accordturbo94@Oct 28 2003, 10:33 AM
This is no theory about it. Whether the IAC is on the back or front, thats is the problem. Sorry about my mistake saying it was on the back. But change it with a good known one and it should solve the problem. Good Luck [/b][/quote]
as for a know good one.. i would be screwed! I have the only h22 in town.. lol!
Old 10-28-2003, 11:53 PM   #18
Rep Power: 14 Jim Truett is off the scale
I have had a vacuum leak in the brake booster cause the same symptoms. Disconnect it, and plug the vacuum port that feeds it, and see if your problem goes away.
2002 Civic Si
6 Speed RSX Type-S Trans
Lots of Overpriced JDM Crap
'94 LX Sedan
'95 Si Trans
JDM D15B force fed with 8 psi
<a href=\'http://www.ecimulti.org/uberdata/\' target=\'_blank\'>Uberdata</a>
<a href=\'http://www.k-series.com\' target=\'_blank\'>K-Series.com</a>
<a href=\'http://www.ephatch.com\' target=\'_blank\'>ephatch.com</a>
<a href=\'http://www.pgmfi.org\' target=\'_blank\'>pgmfi.org</a>
Jim Truett is offline   Reply With Quote
Old 10-29-2003, 12:32 AM   #19
Originally posted by Jim Truett+Oct 28 2003, 11:53 PM--><div class='quotetop'>QUOTE(Jim Truett @ Oct 28 2003, 11:53 PM)</div><div class='quotemain'> <!--QuoteBegin-Accordturbo94@Oct 28 2003, 10:33 AM
I have had a vacuum leak in the brake booster cause the same symptoms. Disconnect it, and plug the vacuum port that feeds it, and see if your problem goes away. [/b][/quote]
hey that sounded pretty good at first but.. than i thought about it.. it wouldnt make it rev so high right away when i start it..
Old 10-29-2003, 03:56 PM   #20
This BLOWS
Old 10-29-2003, 04:08 PM   #21
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
MKy car used to do this and it turned out to be a vaccuum leak. Have you pulled the Intake manifold? You might want to consider replacing the IM gasket, that is what fixed mine.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 10-29-2003, 04:39 PM   #22
Rep Power: 25 SixtySecondAssassin is off the scale
yea, after my 'r' manifold swap, i could never get the throttle body to seal right. i tried over torquing and ended up snapping a stud.
get some throttle body cleaner and spray around suspicious areas, if your idle changes, you've found the culprit.
.....deagle.....
SixtySecondAssassin is offline   Reply With Quote
Old 10-29-2003, 10:07 PM   #23
Im using the hondata intake manifold gasket. it does not leak. Please remember my car was fine before!!!
Old 10-29-2003, 10:25 PM   #24
Originally posted by Accordturbo94+Oct 29 2003, 12:32 AM--><div class='quotetop'>QUOTE(Accordturbo9 4 @ Oct 29 2003, 12:32 AM)</div><div class='quotemain'>
hey that sounded pretty good at first but.. than i thought about it.. it wouldnt make it rev so high right away when i start it.. [/b][/quote]
Yes it might. Remember the ECU won't correct for a high idle right away. It takes a few seconds. Once a high idle condition is found, the ECU will try to reduce it by reducing the orifice size of the IAC valve. If the vacuum leak is too great, and the engine is getting too much air at idle from a vacuum leak, the ECU may oscillate the IAC valve trying to reach proper idle mixture. Anyway, try it. All you have to do is remove one vacuum line. It is a hell of alot easier than pulling the throttle body or IM.
2002 Civic Si
'94 LX Sedan
'95 Si Trans
Old 10-30-2003, 01:32 AM   #25
Originally posted by Jim Truett+Oct 29 2003, 10:25 PM--><div class='quotetop'>QUOTE(Jim Truett @ Oct 29 2003, 10:25 PM)</div><div class='quotemain'>
Yes it might. Remember the ECU won't correct for a high idle right away. It takes a few seconds. Once a high idle condition is found, the ECU will try to reduce it by reducing the orifice size of the IAC valve. If the vacuum leak is too great, and the engine is getting too much air at idle from a vacuum leak, the ECU may oscillate the IAC valve trying to reach proper idle mixture. Anyway, try it. All you have to do is remove one vacuum line. It is a hell of alot easier than pulling the throttle body or IM. [/b][/quote]
Right again.. I havent tryed it yet! I AM going to tomarrow! But when ive started it before the revs never went so high.. to get it warmed up! Im talking 2900rpms when i start it up when the motor is cold!
Fixing an erratic Idle pissedoffsol General Tech Articles 2 10-22-2004 01:24 PM
High idle problem highperboi General Tech and Maintenance 0 03-28-2004 10:39 PM
High Idle and Black Sute Out Tail Pipe! Accordturbo94 General Tech and Maintenance 20 03-12-2004 11:22 PM
Stumped w/ a High Idle mrvanparys HYBRID -> EG-EK / DC 7 12-01-2003 12:45 AM
swapped in a gsr in a EK..now high idle problems ddong2lee HYBRID -> EG-EK / DC 3 11-10-2003 12:04 AM
