#1 | |
Ride: 93 del Sol Gas sipper
Read this on teamintegra.net and since I can not link them (pointless because you must be a member to view) so I ended up just quoteing it.
Collin Material Science and Engineering Michigan Technological University |
Well I run 93 and will always run 93, when I go to the track I dump in a little amount of the 100. Honda motors are pretty high compression motors from the factory though as opposed to most other cars so in that case I think it's fine.
Milan __________________
so basically your saying you should run the correct octane called for by your engine? Boy, and people call me Captin Obvious
![]() __________________
Did I just say something interesting or funny? Check out my blog for more... http://campassmore.wordpress.com/ |
My Vtec is biger then urs
I ran 87 in my B16 everyday till I went turbo
never had any problems |
#5 | |
#7 |
In Japan where all Hondas are born they use 100+ octane from the pump (thats all they use) so the Honda engineers anticipated this and tuned the ECU accordingly. That being said i dont think USDM motors and ECU's were designed to use 100+ octane since they dont allow that in the US on the road for pollution reasons (i think!?).
The JDM motors and ECU's were designed to use 100+ octane (higher compression, more advanced timing,etc) and they should respond better to higher octane. My car (JDM Accord SiR-T) is like Jekyll and Hyde when i use 104 compared to the 93 pump gas i use regularly. And all the Turbo's (Skylines, Evo's, Impreza's, Soarer's etc, etc) and Hondas alike all say the same thing when they use 104 and they all are JDM. Im just throwing this in also but certain JDM turbo cars that are used to running on 100+ octane are suddenly switched over to 93, the ECU's knock sensor detect the inferior octane and then lower the boost to compensate for the less knock resistant fuel. The engine therefore produces less power than before. I've heard that you have to disconnect the battery to allow the ECU to reset and to recognize the higher octane fuel when you switch back. Just adding my 0.02 cents. |
#8 |
I belive you are right JDMSpec...all usdm dohc vtec motors call for 93 octane gas from the factory. To gain power from a higher octane gas, the ecu and timing must be adjusted accordingly.
Dave Philippians 4:13 |
#9 |
But also relize that alot of people when doing swaps dont use the JDM ECU which is designed for the high octane because the JDM ecu also limits everything at 112mph or some crazy speed.
#10 |
also the JDM motors have slightly higher CR.
2005 Mitsubishi Lancer Evolution 8 2004 BMW 325i 2000 Mercedes Benz ML 430 1994 Honda Civic Del Sol VTEC (race kaa) |
#11 |
so what octane does honda call for on the b18c1? or any other USDM DOHC VTEC engines for that matter?
#12 |
I always assumed the minimum was 91?
hey, what was the actual whp loss on that dino, i can't seem to visually see it. Milan __________________
#13 | |
Member of the 20 nut club
looks like 5hp and tq
МОΛΏΝ ΛΑΒΈ |
#14 |
My experience with Hondas, don't use 10% Alcohol (Ethanol Fuels).
Safe Stock Gas Performance 8.1:1 to 9.6:1, max rev < 6300 - 86 Octane 9.6:1 to 10.1:1, max rev < 6300 - 87 Octane 8.1:1 to 9.6:1, max rev < 7300 - 87 Octane 9.6:1 to 11.0:1, max rev < 9300 - 90.5 Octane (91 to be safe) The S2000 is a high rev, high compression motor, and all honda asks for 240hp 4 banger is 91, so why on earth would Honda require a motor like in most civics and accords (which are economy vehicles!!!) to use anything greater than 87? GSR and ITR are different stories and their valvetrain and pistons show you that. Now until our B series get advanced timing, high comp pistons, and redline at 9000, or until we have a performance package that brings crank hp to 240, we have nothing to worry about. Octane booster not required and not recommended in cars with headers and an exhaust. make something significant internally, then it's a different story. nuff said. EDIT: But! SCC did a 350Z test and upped the octane on a stock car and saw same performance in the low end but the top end pulled 1-2hp. |
#15 |
Admin with a big stick
Ride: 2003 S2000
There is a LOT more to it than just compression and engine speed.
#16 |
i always use the highest grade octane 91-93.5 , i like to baby my car with stuff like that, and i only use one fuel, and that is amoco fuels. untill i take my car to the dyno to see it for myself, i will continue to use the best legal octane there is.
1988 Crx Si for sale 1995 Integra GSR Supercharged <a href=\'http://www.hondaswap.com/forums/index.php?showtopic=41282\' target=\'_blank\'>Crx Bseries swap mounts+axles+shiftlinkage, gsr leather seats, racing seats, other goodies for sale</a> |
#17 |
dude it's only like 20cents more a gallon for high octance. Thats 2$ per tank. My attitude is that I'd rather spend the extra 2$ and be sure I have the best gas.
"Our enemies are innovative and resourceful, and so are we. They never stop thinking about new ways to harm our country and our people, and neither do we." -The thought provoking George W. Bush |
#18 |
Ride: 94 Integra GSR
1994 Acura Integra GSR Power: AEM V2 Cold Air Intake GReddy 4-2-1 Header GReddy Evo 2 Exhaust Suspension: Tanabe Sustec Pro S-0C |
#19 | |
Ride: 2006 Audi A4
"Good talk... I'll see you out there." |
#20 |
Banned
bottom line is....higher octane will help ONLY if your car needs it because it misfires/preignites with lower octane. higher octane gas has no power-enhancing effect in itself.
when u advance yor timing, you are effectively causing some misfire, so using high octane with advanced timing MIGHT give u some kind of extra pep, but i am not sure. honda engines' timing is computer controlled. in a nutshell: octane is a gasoline's ANTI-KNOCK rating. has nothing to do with adding power. |
#21 | |
Think of it this way, you piss in your pisser, maybe 1.6 gallons, the water turns yellow, now go piss in a Jaccozzi (please not one that I go to or others for that matter) it stays clear. Is there piss in both sets of water? yes, but the spa would be super water down, no one would even notice. The octane booster averages out to basicly a few tenths of an octane point. __________________
#22 | |
I don't know about you guys, but on my BPU DX motor, I have my timing advanced the maximum by the distributor rotating method. I figured that was a given. That is reason enough to use the better gas __________________
#24 | |
Ride: 2007 Scion TC, 2005 Suzuki GSX-R 600
Think of it this way, you piss in your pisser, maybe 1.6 gallons, the water turns yellow, now go piss in a Jaccozzi (please not one that I go to or others for that matter) it stays clear. Is there piss in both sets of water? yes, but the spa would be super water down, no one would even notice. The octane booster averages out to basicly a few tenths of an octane point. [/b][/quote] Umm, most octane booster says it will increase the octane of a 10gallon gas tank 3 pts, meaning if you are running 10 gallons of 91, then with the octane booster it bumps it to 94. Read the bottle mang. __________________
When this is all over I think we should get an apartment together. |
#25 | |
welp seeing that in my area the only octane levels available are 87 89 93 and sunoco has 94
ill stick to 93 im not about to put 89 in a JDM ITR engine and when i go to the track i will continue to put $20 worth of 100 in if im going to be out there reving the piss out of the engine for 30 min at a time id rather have $20 worth of insurance against blowing the engine the fuck up than 2 more HP __________________
МОΛΏΝ ΛΑΒΈ |
| B Series Cam Guide | JDMilan | Reference Materials | 35 | 04-13-2007 09:26 PM |
| high octane race gas in a stock motor | ahedau | General Tech and Maintenance | 7 | 07-24-2004 06:46 PM |
| Looking to make high horse power | tenshot | Engine Building | 1 | 10-14-2003 11:25 AM |
| why does my car run WORSE on high octane | sportlinecrx | General Tech and Maintenance | 4 | 10-21-2002 05:08 PM |
| Benefit of using Higher Octane? | pissedoffsol | General Tech Articles | 0 | 09-28-2002 01:37 PM |
