HONDA GURU please help! ect problem
Old 10-01-2008, 09:55 PM   #1
Rep Power: 0 coreylol is on a distinguished road
Default HONDA GURU please help! ect problem
getting a code 6, ect
so first off..the car is a 89 crx HF with a obd0 b16 swap. i did a search and i found the info on the faq about getting a resistor and plugging it in to see if the problem is with the sensor or the wiring. well i got the resistor (330 ohm 1/2 watt spec, or one from Radio Shack part# 271-1113) and i still get a cel 6 and bad idle. i also have the factory service manual for the crx and i went through the process of testing with a multimeter. and the wiring seems to be alright. i get 5v's on the red wire and i get 5v's between the red and green wire on the ect. i finally broke down and bought a new ect and tried that....still getting a cel!!!! one thing that did turn the cel off was when i restarted the car after it was already warmed up...i guess because the car doesn't look at the ect after its warm? i'm not sure. can anyone help??
coreylol is offline   Reply With Quote
Old 10-01-2008, 10:07 PM   #2
Hondaholic
prpprimo's Avatar
Ride:  91 hatch z6/ 98 coupe z7
Rep Power: 4 prpprimo is on a distinguished road
Send a message via AIM to prpprimo
Most all sensors are monitored constantly by the ECU.
Have you reset the ECU after replacing parts or disconnecting sensors?
Its a must. Trouble codes typically remain stored even after repairs.
Pull the ECU back up fuse or disconnect your battery for a couple minutes.
prpprimo is offline   Reply With Quote
Old 10-01-2008, 10:07 PM   #3
Regular Member w/ Cheese
YBLEGAL's Avatar
Ride:  2000 EJ8 w/ SiR-II
myspace
Did the swap ever function correctly?
Radiator cap not pressurizing? Maybe way off base but thowin that out there.
YBLEGAL.NET ProfileProjectsParts For SaleSteel Braided Brake Lines • Front Camber Kit (Price Drop) • Manual Brake Pedal
Old 10-02-2008, 02:20 AM   #4
hah...yeah i reset the ecu. every time i make any change i reset the ecu.
and i'm pretty sure the system is holding pressure...it's not leaking anything. and when i put the new sensor in..i took the cap off and some fluid came out because of the pressure.
i have one more question. is it possible to just hardwire the sensor to the ecu? or are the wires connected to anything else?
Old 10-02-2008, 02:35 PM   #5
ok. weird thing happened today. i'm sitting at a red light and the cel turns off and my idle goes back to normal...what the hell?
Old 10-02-2008, 02:41 PM   #6
^^ Likes Bewbies
George777's Avatar
Ride:  Rex, Yamaha Virago, CB900F Supersport
Rep Power: 119 George777 has a reputation beyond reputeGeorge777 has a reputation beyond repute
George777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond repute
Idle gremlins.
See if it still does funny stuff tomorrow, or after the car has cooled down and not run for a while.
Originally Posted by Blanco View Post
Eat shit and fucking die you ignorant redneck.
Originally Posted by B16RacerN2NR View Post
I don't know how to do plastic surgery but I love titties, you don't see me trying to go around giving breast implants do you?
Originally Posted by phyregod View Post
Yup, Its sex on wheels. Violent, vigorous sex. With a super model. Scratch that, super model twins.
George777 is offline   Reply With Quote
Old 10-02-2008, 08:13 PM   #7
yeah its weird man. the light went off today after the car warmed up. then i drove home and let it sit for a minute. started it back up...and the cel came on. then i reset the ecu and started it backup and it hasnt come back on since....weird?? hopefully it wont come back...crossin my fingers!
Originally Posted by George777 View Post
Idle gremlins.
Old 10-02-2008, 09:31 PM   #8
alright. so i let the car cool down completely and then started it up and drove around and the cel came on instantly. then when the car was warmed up.....it went off. what the hell? anyone know whats goin on here? the sensor is brand new
Old 10-10-2008, 07:22 PM   #9
update. i tried a new ecu. still getting the cel! does anyone have any idea what this could be??
Old 10-11-2008, 03:30 PM   #10
up. i need help!!!
Suspension Guru's MXDesa Wheels / Suspension / Tires / Brakes 11 04-18-2006 07:59 AM
Any SCCA guru's out there? phyregod Racing and Driving Techniques 44 01-16-2006 05:20 AM
For all you Guru's MXDesa HYBRID -> EG-EK / DC 2 06-13-2004 08:05 PM
Guru Guru Sushi ROck'S..... Airjockie Members' Lounge 23 11-07-2003 03:48 PM
Computer help From Guru's for a Guru CRX-YEM Members' Lounge 13 06-28-2003 01:48 PM
