How to bleed clutch fluid?
Closed Thread
Old 04-03-2005, 11:04 AM   #1
Rep Power: 12 NyQuiL_AcCoRD is off the scale
Send a message via AIM to NyQuiL_AcCoRD
How do I go about with bleeding the clutch fluid from a H22a1. Every time I push down on the clutch pedal, it drop straight down to the floor. I checked out the hydradic on the transmission, and found fluid had leaked out. A good amount clutch fluid had leaked out everywhere. I just want to bleed the clutch fluid, and tighten bolts to see if it was a lose bolt. So, I need some information on how to bleed the clutch fluid. Thanks!
1. 95' Honda Accord EX Coupe, 1994 JDM H22A (Front-Clip), AEM Cold Air Intake, JDM Headers (JAZMA), 2.25' Test Pipe, World Sport 2 Exhaust.
2. 05' Suzuki GSX-R 1000 - ( Future Mod ) Tri - Oval Yoshumira Full-Exhaust system / Carbon Fiber.
NyQuiL_AcCoRD is offline
Old 04-03-2005, 11:20 AM   #2
Rep Power: 29 VTECPOWER is off the scale
Send a message via AIM to VTECPOWER
The bleeder should be near the transmission and should have a rubber cover over the end of it, you will need someone to help you with this,take the cap off of the clutch master cylinder, then loosen the bleeder and have someone push down the clutch pedal and hold it to the floor, then tighten down the bleeder, then the pedal can be released from the floor, check the fluid level, repeat if necessary.
DB8 450whp project......
VTECPOWER is offline
Old 04-03-2005, 11:46 AM   #3
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
Rep Power: 122 92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
you can do it by yourself.
Put the wrench on the end of the bleeder valve, put a hose over the nipple, put the other end of the hose in a cup of brake fluid, open the valve, press and release the pedal 20 times or so. Close the valve, get back in press and release the pedal...it will get stiff.
DO NOT PM ME WITH TECH QUESTIONS!!!
Current Rides
1992 Chevy S-10 Ext. Cab
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned,
253whp
1994 Civic VX Hatch, 1992 b18a1 swap
1993 Civic CX Hatch, 2000 B18b1
92civicb18b1 is offline
Old 04-03-2005, 12:05 PM   #4
Soy Boricua
Estorvito's Avatar
Ride:  BoOsted fodo civic
Rep Power: 32 Estorvito will become famous soon enough
Send a message via AIM to Estorvito Send a message via MSN to Estorvito myspace
Thats How I do It......
LBR=LowBudgetRacing
My civic build thread
Estorvito is offline
Old 04-03-2005, 06:23 PM   #5
Ride:  93 del Sol Gas sipper
Rep Power: 101 asmallsol is a jewel in the roughasmallsol is a jewel in the roughasmallsol is a jewel in the rough
Originally posted by Estorvito+Apr 3 2005, 12:05 PM--><div class='quotetop'>QUOTE(Estorvito @ Apr 3 2005, 12:05 PM)</div><div class='quotemain'><!--QuoteBegin-92civicb18b1@Apr 3 2005, 11:46 AM
[/b][/quote]
Just make sure you keep adding fluid. The resivoior for fluid is TINY. After 8 pumps or so, the thing is already empty, then you have to do it all again. Also, the pedal will have zero pressure when you pump it, so it won't come up on its own. I always do it barefoot and just pull it up with my toes. But yea, you don't need anyone else there because the valve is a one way valve so no air come back in.
Collin
Material Science and Engineering
Michigan Technological University
asmallsol is offline
Old 04-03-2005, 08:28 PM   #6
tab
Ride:  03 Avalanche
Rep Power: 51 tab is on a distinguished road
Send a message via MSN to tab
If you're really slick, and pump slow, it's also possible to run that same hose right back to the master resevoir. No fluid is lost except for what is needed to displace the air in the system. It can be messy if you aren't careful.
2003 Chevy Avalanche
Leather, Moonroof, Z71, tow package, bose+six disc, nice.
1992 Accord EX (sold to good friends)
JDM H22A
H22A Auto Tranny w/LSD
I/H/E -- All stainless w/2.5 inch Catback
1968 Oldsmobile Toronado
Project car, 455 ci front wheel drive, nasty.
tab is offline
Old 04-03-2005, 08:33 PM   #7
Soy Boricua
Estorvito's Avatar
damn, you're going to need a long hose for that....I'd rather buy more brake fluid....I thought I was CHEAP jk
LBR=LowBudgetRacing
Old 04-03-2005, 09:23 PM   #8
Thumbs up
Yeah, I bled the clutch fluid with the help of my buddy. I found out what the problem was with the clutch. The slave cylinder has a crack which is leaking the clutch fluid. I'm planning to replace the slave cylinder. So, I guess I'll need help with replacing the slave cylinder. Does anyone know how to it replace the slave cylinder? Thanks to everyone for the helpful advice for bleeding clutch fluid.
Old 04-04-2005, 03:50 AM   #9
The Trisexual
the slave is easy to replace
2 bolts, 1 hydraulic line....maybe 2 extra.
Pull it off, put the new one on and bleed away.
It's real easy on FWD hondas....now on a FR Porsche, it was a bitch
Current Rides
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
253whp
Old 04-05-2005, 01:57 AM   #10
tab
Ride:  03 Avalanche
JDM H22A
tab is offline
Old 12-12-2008, 01:13 AM   #11
Rep Power: 0 benitorod2 is on a distinguished road
ok how do you bleed it on a 95 integra gs-r. info plz.
benitorod2 is offline
Old 12-12-2008, 12:00 PM   #12
ZOMG WTF!?!
94H_Ex's Avatar
Ride:  78' Chevy C10, 84 Nissan 720
Rep Power: 52 94H_Ex has a reputation beyond repute
94H_Ex has a reputation beyond repute94H_Ex has a reputation beyond repute94H_Ex has a reputation beyond repute
Send a message via AIM to 94H_Ex myspace
Instructions to bleed Clutch Release system.
Tools needed:
A sharp a object. such as a Knife or shank.
A good set of eyes.
Procedure:
Step 1: Locate the rubber section of your hydraulic clutch line that feeds into the Clutch Slave Cylinder.
Step 2: Take the knife and stab it.
Step 3: Using your get set of eyes, watch it bleed.
^^^^ dont do that...
OP, if you had fluid everywhere and its not from a broken line. then your going to need to replace that slave cylinder. which should cost about 20 bucks (for a civic) or so. clutch cylinders arent hard to do, but bleeding them is fun too for me atleast. Basically your going to bleed it like brakes. your buddy gets in there and pumps the pedal, then holds it down, then you release the pressure. then you repeat till your satisfied with it.
Do not PM me with tech questions
Support your local Strippers.
94H_Ex is offline
Old 10-11-2009, 02:16 PM   #13
Greenhorn
Rep Power: 0 djdeito is on a distinguished road
ask your friend for help or if you could find a way to press and hold the clutch pedal down using your car's driver's seat then great.
1.open your car's hood and the clutch fluid reservoir.
2.tell you friend to press down the clutch pedal and hold it there.
3.you: locate the slave cylinder, and as your friend has his foot pressing down the clutch pedal you will see that the pushing rod of the slave cylinder is extended (open). now open the bleeder (becareful with the fluid not to spill on your eyes) and as you open the bleeder you will see fluid coming out as well as the pushing rod going back to its original position, when the pushing rod stops and with the bleeder still open, push the rod all the way inside untill it stops and hold it there, now tighten the bleeder and then let go of the pushing rod. as you do this extra step you will see more fluid and some air bubbles come out through the bleeder.
4.do not pull up the clutch pedal yet. add some fluid to the reservoir, enough so that the level is at the max line.
5.you or your friend could now pull up the clutch pedal. check the reserviour again, and add fluid enough so that the level is at the max line.
repeat steps 2 through 5 four times. when you are done do not forget to close the fluid reservoir and remove any tools used from the engine bay, BUT remember to go for a ride.
djdeito is offline
Old 10-11-2009, 10:38 PM   #14
99sidude's Avatar
Ride:  gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
Rep Power: 50 99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of
Send a message via AIM to 99sidude
Thanks for the input. Unfortunately you are beating a dead horse because you are adding to a 5 year old thread!
Try and help out on newer threads. Thanks
edit:
HOLY 36,000 views. This one is a money maker
Originally Posted by Celerity View Post
The worst thing that car ever had installed was your lying two-bit fat ass in the left seat.
My Build: http://hondaswap.com/auto-multi-medi...sc-buld-94841/
93' dx hatch
jdm b18c - jrsc 8psi
s300 440cc RC's
99sidude is offline
Closed Thread
