How Come I Have No Rpm S
Old 01-20-2003, 07:49 PM   #1
slammedb18acivic is off the scale
Send a message via AIM to slammedb18acivic
when i did a port and polish job on my intake manifold and put it back on i went into my and reved it up helping circulate the coolant through all the sensors. I heard a click and i lost my rpm gauge and all lights like blinker lights, check engine because it was on after my swap, only light i have is battery light when i turn my battery on not to mention i do have dashboard lights. when i turn my lights on. what is wrong here ? ?
slammedb18acivic is offline   Reply With Quote
Old 01-20-2003, 09:28 PM   #2
Ride:  93 del Sol Gas sipper
asmallsol is a jewel in the roughasmallsol is a jewel in the roughasmallsol is a jewel in the rough
sounds like a short somewhere or you just blew a fuse, When you say you dont have rpms you mean your tach does not work or your car will just no longer rev past umm...3k?
Old 01-21-2003, 08:10 PM   #3
when i meen i have no rpms, i have no rpms, no speedometer, blinkers,only have dashboard lights and battery light. ill check for a short maybe i hit something when i installed new clutch cable under dash, but all fuses are good.my car goes to high rpms, but sputters like she doesnt wanna go and then it feels like i hit vtec and the car shoots off. then it will sputter again and repeat.
Old 01-21-2003, 08:43 PM   #4
i currently have my si map sensor installed along w/ a believe a old si fuel filter. should i put ls in each along w/ an after market fuel pump. its like its not getting what it needs
Old 01-22-2003, 01:15 AM   #5
tomtom is off the scale
Send a message via AIM to tomtom
like the man said u should check all the fusess
under the dash and the power distrubution center under the hood.
tomtom is offline   Reply With Quote
Old 01-22-2003, 10:33 AM   #6
i checked all fuses , everything is good except my turn signal and reverse one was blown. this wouldnt be it though right.
Old 01-22-2003, 12:07 PM   #7
It could, just replace that fuse, they are like a dollar. If it is just your gauge cluster, take the cluster out and see if something got disconnected.
Old 01-22-2003, 04:41 PM   #8
zueke is off the scale
Send a message via AIM to zueke
The mere mention that you had 2 blown fuses AND you heard popping sound when you first turned on the car clearly tells us that you have some sort of a ground problem. Check all your wires both behind your fuse boxes, and in the engine bay to make sure you didn't have a power wire fall out somewhere and get grounded on the body. That could blow certain fuses, and stop the correct voltage from getting to your sensors, dash, and ECU.
Oh, and make sure you disconnect both the positive and negative terminals to your battery when doing this work. That way you are a lot less likely to accidently spark the battery to something and blow more shit up.
John
zueke is offline   Reply With Quote
Old 01-27-2003, 01:04 PM   #9
could i have a bad relay. if so where would it be located ? i have no shorts and all fuses are good .
Old 01-27-2003, 01:14 PM   #10
Ride:  '92 Civic CX
D See 2 is an unknown quantity at this point
Send a message via AIM to D See 2
there is such thing as a fusible link... it blows a fuse when you disconnect a certain wire. if the fuses that blew were on a fusible link, then it does not necessarily mean that there is a ground or short circuit problem.
D See 2 is offline   Reply With Quote
Old 01-27-2003, 10:42 PM   #11
so what are you getting at, check what in the car? thanks
Old 01-28-2003, 01:27 PM   #12
whats up i fixed and thank you guys for your help. it ended up being a short and that turn signal fuse. everything wrks great except for a damn vaccum leak making my car idle funky. thanks again
