How to identify a tranny?
Old 06-05-2007, 12:50 AM   #1
Ride:  88' CRX ZCt
Rep Power: 7 demonboy1300 is on a distinguished road
Send a message via AIM to demonboy1300 myspace
Default How to identify a tranny?
Ok so i bought a dohc ZC CRX off a kid that let it sit forever, so i figured id boost it and have some fun with it. i wanted to know how i can identify the tranny, i want to throw in a stage 1 or 2 clutch. but i dont know what kind of tranny it is? its in an 88 Si
but is there any real way to find out if its an Si tranny or identify what it is? how many possible trannys line up with dohc zc?
appreciate it
D
God Created Turbo Lag To Give V8's a Chance!
demonboy1300 is offline   Reply With Quote
Old 06-05-2007, 02:12 PM   #2
Dismember
Ride:  Whatever i can get behind the wheel of
Rep Power: 263 klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
"She" will have an Adam's apple and a bulge in her crotch.
jk.
I have no useful information, Jerry owns me
Go to work, Act normal, Believe the News, Save for your old age, Obey the Law
Repeat after Me: I am Free
klyph is offline   Reply With Quote
Old 06-05-2007, 02:20 PM   #3
jlicrx's Avatar
any 88-91 CRX/Civic L3 transmission (even 4 speed) will bolt to the ZC - you cannot tell by looking at it what the gear ratios are that are inside - do you have an intermediate axle shaft on the driver's side? - the ZC transmission is the only one to use the intermediate shaft - before you buy a clutch, you need to find out what flywheel you have and the number of splines on the transmission input shaft - 88s had 21 splines and 89-91 had 20 splines - 88 and 89 had flywheel for 200mm diameter clutch and 90-91 had flywheel for 212mm diameter clutch
here is how you can tell which transmission it probably is (unless someone put together some sort of hybrid)
ZCspeed Racing
SI tranny or whether? Atownz05 Civic and del Sol - EG and EK 13 03-16-2008 09:41 PM
f22b2 tranny ludecrasy87 Accord 3 04-28-2007 06:38 PM
gsr tranny to ls tranny swap. cracked bellhousing bannacrx Integra 8 04-02-2007 12:47 PM
s20 tranny type of oil BORICUAFLAVA2 General Tech and Maintenance 4 06-29-2006 06:18 AM
WTF my Tranny is bleeding!?! Citizen_Insane General Tech and Maintenance 5 05-04-2004 02:53 PM
