I think this is the right forum
Old 07-10-2005, 10:42 PM   #1
Rep Power: 19 CiViC_SOHC is off the scale
Send a message via AIM to CiViC_SOHC
noobie question I know but I was wondering...how the hell do you increase your redline? cuase my buddy has a B16A2 and his redline is at 9000 and I know it doesn't start that high so ya I was jw thanks!
1992 EG8 Civic Sedan / '98 D16Y7 swapping a D16Z6...TURBO!
Support the local Performance shop. <a href=\"http://aeiperformance.com/\" target=\"_blank\">AEI performance</a>
CiViC_SOHC is offline   Reply With Quote
Old 07-10-2005, 10:48 PM   #2
sohcslammer's Avatar
Rep Power: 35 sohcslammer is an unknown quantity at this point
Depends on what OBD you are. If you are obd 0 then it's turbo edit , or something like that. If you are obd 1 then you can chip it for $20, get hondata, uberdata, crome, etc.... If you are obd 2 then you are stuck with converting to another obd, or using aem, motec, fast, etc....
Latest project -
1 fucking fast 99 SI
sohcslammer is offline   Reply With Quote
Old 07-10-2005, 11:19 PM   #3
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Rep Power: 288 Calesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud of
Yup- just run a chip with a raised redline or intercept the VSS signal on your own.
Old 07-11-2005, 11:35 AM   #4
Citizen_Insane's Avatar
Rep Power: 51 Citizen_Insane will become famous soon enough
Send a message via AIM to Citizen_Insane
However, realize that rasing your redline on a stock car won't make you faster. Most honda engines can rev much higher than stock safely, but they stop making power arround the redline. You gain nothing unless you have cams, vavle springs, and retainers meant to keep up. If you needlessly over-rev your engine without the before mentioned steps, you could easily float a valve....and for what reason? You would be faster shifting before then anyway.
No tech questions through PM please!
B16 CRX....you will be missed
Citizen_Insane is offline   Reply With Quote
Old 07-12-2005, 12:21 PM   #5
o ok I was jw lol cuase I know my friends Si its all motor and his redline is at 9000 I didn't know if that helped or what not...im going to be getting chipped ecu for lower vtec engagement and diff fuel maps anyways becuase im gonna be turboing so ya lol...thanks for all the feedback guys sorry for the newb ?
Old 07-12-2005, 09:19 PM   #6
Calesta's Avatar
Ride:  2003 S2000
No problem. While you're spending the money on getting chipped- just throw the chip away and get a real custom program made for your turbo setup. It'll cost you a few hundred more, but you'll get a lot more power, better economy, plus your engine will last a LOT longer. It's worth the extra cost up front.
Old 07-12-2005, 09:23 PM   #7
im gonna get crome...
Old 07-12-2005, 09:55 PM   #8
Calesta's Avatar
Ride:  2003 S2000
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
