idle jumps up & down & car dies on carb crx HELP!!!
Old 01-27-2006, 12:47 PM   #1
twiztedvanilladevil is off the scale
I cant keep my 1987 carbed crx running. I get it started & it revs up & down real high & dies unless I keep punching the gas can anyone help me do I need to install a manual choke?
thanks
twiztedvanilladevil is offline   Reply With Quote
Old 01-27-2006, 12:51 PM   #2
DAT CAT
Battle Pope's Avatar
Ride:  2007 Civic LX
Battle Pope has a reputation beyond repute
Battle Pope has a reputation beyond reputeBattle Pope has a reputation beyond repute
Sounds like it's either a vaccum problem or it's not getting proper fueling.
Wrong forum BTW.
Battle Pope is online now   Reply With Quote
Old 01-27-2006, 12:55 PM   #3
TTIWWOP
reckedracing's Avatar
Ride:  90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
reckedracing has a reputation beyond repute
reckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
moved FTW
vacuum leak, map sensor issue?
are you in a cold temp?
does the carb'ed version have a coolant temp sensor?
is your CEL on?
what if you rev it till it warms up?
then will it run ok?
reckedracing is online now   Reply With Quote
Old 01-27-2006, 01:35 PM   #4
corvetteguy is off the scale
that was happening with my celica, replaced the map sensor, fixed it right up
corvetteguy is offline   Reply With Quote
Old 01-27-2006, 04:11 PM   #5
Yes the car is cold when 1st starting it, it will stay running once warm but stays reving at 3000 rpm's . Any suggestions?
<div class='quotetop'>QUOTE(reckedracing @ Jan 27 2006, 01:55 PM) Quoted post</div><div class='quotemain'>
moved FTW
is your CEL on?
[/b][/quote]
