i have a 93 delsol swaped a 99b16a2 obd2 motor in it.ok,friend changed eveything
to obd1 and said it would work.useing gsr p72 ecu,ls dist,and the del sol wiring harness single-vtec. the motor starts and when the motor lets it self rev high enough the v-tech does pop over..heres the problem when i start it the idel is stedy at 700rpm a few seconds later it keeps jumping 700-1100rpm.it does not want to idel right the air to fuel gauge reads rich and once in a while lean,but manly rich.it will rev but then cut me off at 5000rpm most of the time.what could be the problem??? |
#4 | |
check engine light stay on but no codes.starts to burn lean latey.still idels funny and if tps how much is one and where can i find one. |
#7 | |
#9 | |
idel starts to jump again after a few seconds. |
| Fixing an erratic Idle | pissedoffsol | General Tech Articles | 2 | 10-22-2004 01:24 PM |
| HONDA IDLE PROBLEMS 92-95 CIVIC | FamilyD | General Tech and Maintenance | 0 | 05-14-2004 11:07 PM |
| Idle problems with h22 | driver1 | HYBRID -> BA-BB /CA-CD | 15 | 10-09-2003 10:36 AM |
| Idle Problems | White Mike | Engine Building | 0 | 04-28-2003 02:23 PM |
| idle problems | slohnda | General Tech and Maintenance | 6 | 10-05-2002 01:05 AM |
