Facebook Twitter
ignition timing w/ no timing belt cover...?
Old 11-18-2009, 01:03 PM   #1
Up a Creek...
Ride:  94 Hatch B16A2
bakerderek0 is on a distinguished road
Default ignition timing w/ no timing belt cover...?
I have a b16a block w/ a b16a2 head. I think my ignition timing is off...but, I don't have a timing belt cover...Are there any other refrence points to hit with my timing light? Has anyone else ran into this or know a way to get around this issue?
I also have some noisy ass LMA's that make it hard to hear what's going on inside my valve train.
When I turn my distributor, all I can hear is a change in rpm...what am I listening for?
bakerderek0 is offline   Reply With Quote
Old 11-18-2009, 01:11 PM   #2
I wear stretchy pants
Taco15's Avatar
Ride:  chevy s-10
Taco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
Taco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
myspace
check you points on the cams at tdc. if they are off just take the belt off with the crank at tdc (cylinder1) and move the cam until the arrows both point up. The one will be off by 1/2 to get the belt on but one its on they align themselves
Taco15 is offline   Reply With Quote
Old 11-18-2009, 01:22 PM   #3
Up a Creek...
Yea, neither cover is on here.
Correct me if I'm wrong, but the process you explained would be for cam timing, not ignition timing. correct? Or am I wrong to think cam timing and ignition timing are different?
Old 11-18-2009, 01:56 PM   #4
Taco15's Avatar
Ride:  chevy s-10
myspace
you are correct. But if you see the exhaust cam is off than i would assume you ignistion will off too.
your right thoough.
the only thing i can think of is to manually adjust the dizzy until the desired rpms is set (700- 600 ish)
I dont think anything will beat the timing light.
Old 11-18-2009, 03:00 PM   #5
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
As far as I know you need the cover.. You can get it close by setting the number one piston to tdc, then aligning the marks on the pulleys with the head itself, but you're out of luck For fine tuning without a cover. Hit eBay for a lower cover at the very least..
Old 11-19-2009, 12:02 PM   #6
Up a Creek...
ahhh.. to ebay it is! I wonder how much of a pain this is gonna be. To the helms!
Old 11-19-2009, 02:24 PM   #7
Taco15's Avatar
Ride:  chevy s-10
myspace
you could just take it to a shop to set the timing. Or just go buy one at autozone.
now that i think of it. You can prolly rent one there too. Put some money down, take it outside, set the timing and bring it right back and get your money.
Old 11-19-2009, 03:00 PM   #8
Up a Creek...
I have the timing light, just no white or red lines to match up the pulley to
Old 11-19-2009, 06:48 PM   #9
!!YTINASNI
phyregod's Avatar
myspace
Can't time it without a reference mark!
!!!!wtb timing belt cover for d16!!! civickid92 Parts: For Sale/Trade/Wanted 2 07-17-2009 09:06 PM
zc dohc timing. all timing marks line up, ignition timing is very retarded 91civicZCdohc General Tech and Maintenance 2 10-13-2008 05:35 PM
timing belt cover?? sevenhillsbilly HYBRID -> ED-EF / DA 1 09-30-2008 10:15 PM
Difference between b16b timing belt and b18c timing belt ??? loverboy HYBRID -> EG-EK / DC 4 09-28-2007 09:49 AM
top timing belt cover 95preludetypes General Tech and Maintenance 6 05-13-2005 11:20 PM
© 2001-2010 HondaSwap.com
a SkeyMedia Network site
