Immobiliser question with engine swap
Old 01-07-2005, 04:16 PM   #1
Rep Power: 0 garz is off the scale
hi
i'm joining this board from the UK - and need a little advice.
trried this [post in the ECU forum - but no replies so am trying again in case anyone here can help
i have a 2003 JDM spec DC5 integra Type R engine on its way to me to be installed as an engine swap.
i have a heap of mechanical and plumbing issues to sort out - but have these in hand.
one thing i know i will have to deal with is the immobiliser
i have the ECU and the engine harness - but not the Key/fob
question is - how do i get around the imobiliser - to get the engine to run.
any input on ways around it or aftermarket ECUs would be very much appreciated
thanks to the BB in advance
garz
garz is offline   Reply With Quote
Old 01-07-2005, 07:10 PM   #2
Rep Power: 59 hcivic.com is on a distinguished road
keep all the reciepts then go to a dealer and they will remove it
hcivic.com is offline   Reply With Quote
Old 01-07-2005, 08:18 PM   #3
Rep Power: 18 nfn15037 is off the scale
Doc from the PGMFI.org board has a hack for it....
http://doctronic.at/eng/product_mobilisizer_a0_eng.htm
Friends Don't Let Friends Apex Early
nfn15037 is offline   Reply With Quote
Old 01-07-2005, 09:10 PM   #4
nice one hondabonded !!
will check with them if it will fit my ecu
