This is a discussion on Installing A/F & Oil Pressure. in the General Tech and Maintenance forum
Is there an easy way of just telling me where I need to hook my a/f up to & same with the oil, The instructions sucks!...
| | #1 |
| Is there an easy way of just telling me where I need to hook my a/f up to & same with the oil, The instructions sucks! |
| | #2 |
| oil pressure- tap off the oil pressure sender. a/f don't even bother unless you have a wideband o2. |
| | #3 |
| What would be the best way to "tap" my oil pressure sender.. I'm just wondering what would the A/F go into? |
| | #4 |
| a/f taps off the o2 signal wire.. i beleive its the green- but don't quote me. the oil pressure sendor, you're going to need the 1/8" BSPT tap into the back of the block just like you would for running a turbo oil feed.. and then all those conenctors, and finally a T, 1 for the pressure gauge, 1 for the oil feed |
| | #5 |
| Thanks for the help! |
| | #6 |
| I'm pretty sure that the O2 signal wire is white, blacks are heater ground, 12v power and the green is O2 signal ground. Thats how I just hooked up my plx air fuel gauge and its working great with the hondata. ![]() go tooil pressure gauge and go to the articles section, it will be under the how to, for oil pressure pickup |
