GNU/Linux Evangelist
Ride: The Cheapest Road Bicycle I could get
Make sure the ring landings are clean. Make sure the ring end gap is correct. Make sure that you follow the instructions when they tell you where the ring gaps should be positioned.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com |
88 C1V1C 53D4N DR1V3R
Ride: 2006 Suzuki Aerio
how does one go about gapping the rings?
and the ring lands better be clean, i ordered the pistons brand new from hybrid garage 2 weeks ago. |
I wasn't sure if they were new or not
![]() To check ring end gap you will each ring from piston 1 into cylinder 1, one at a time. Make sure that the ring is installed level by pushing the piston down on the ring (don't push the ring into the cylinder too far). Use a feeler gauge (the tool you use to measure valve lash) to measure how far apart the ring ends are. Then use a file to widen them if the need it, make sure to debur the edges after filing. __________________
#6 |
No problem, those are really rough instructions. Do a google search if you want more specific instructions.
| piston rings | t3t4si | Forced Induction | 7 | 01-09-2004 11:13 PM |
| WTB... piston rings for .25 over | DA69 | Parts: For Sale/Trade/Wanted | 4 | 08-15-2003 11:34 AM |
| Piston Rings? | wildbillhatchbac | Engine Building | 11 | 05-08-2003 05:21 PM |
| Will It Fit? Piston Rings? | Liquidblaze | Engine Building | 0 | 03-13-2003 02:23 PM |
| Piston Rings | Liquidblaze | Engine Building | 1 | 03-03-2003 08:36 AM |
