I saw a topic about an intake manifold and I got to thinking:
1. How hard are they to install? 2. What is a good one? 3. Is it worth it? 4. Does it effect smog for CA? The reason I am asking it is because a lot of people say it is a good idea but I hear some people say they are not worth it. I believe Skunk2 makes a good one but I dont even know who whould make another one. It wouuld be going on a '96 GSR. Thanks in advance. ![]() __________________
The <a href=\'http://www.101deals.com/Forums/index.php?act=idx\' target=\'_blank\'>'other'</a> forum. |
Isnt an Intake Manifold the most power adding bolt on you can get? I dont have an aftermarket one so dont take my work for it.
<span style=\'color:red\'><span style=\'font-family:Geneva\'>94 JDM H22A|5spd-LSD|GSR Spec Brembo Cross Drilled and Slotted Rotors| GSR Front Calipers| SS Lines|Tokico Illumina Struts| Skunk2 Coilovers| AEM Fuel Rail| ACT Stage 3 Clutch /w Xtreme Pressure Plate| 8lb Kaiten Kairu Super Flywheel</span></span> |
Easy, just bolt on. 2. What is a good one? Depends on who you ask. 3. Is it worth it? I think so, I did it to my car. 4. Does it effect smog for CA? It shouldn't, as long as you can still hook up your O2 sensor. __________________
Never send a foot to do a hand job. "Arguing over the internet is like the special olympics...even if you win, you're still retarded." "You can't polish a turd and call it something." - Steve Watson BAR # N5371070 ~~~It's California legal BITCH!!~~~ <span style=\'font-size:14pt;line-height:100%\'>Come <a href=\'http://www.101deals.com/Forums/index.php?act=idx\' target=\'_blank\'>Here!</a> And say what you want! Anything goes!!! </span> |
#4 | |
93 Del Sol - D16Z6 Turbo |
#5 | |
Ride: 93 del Sol Gas sipper
yea and no. If your really into things like autox and you try and be compeditive with your mods. It can be a smart idea since it is legal in DSP. With the GSR intake, the intake is huge and pretty bulky. Every few pounds count. Also, I have seen some say up to 12 hp on one. __________________
Collin Material Science and Engineering Michigan Technological University |
#6 | |
2005 Mitsubishi Lancer Evolution 8 2004 BMW 325i 2000 Mercedes Benz ML 430 1994 Honda Civic Del Sol VTEC (race kaa) |
#7 |
If you don't have a lot of cash.....then stay with the GSR maini!!
Why????? Cuz the secondary butterflies in the manifold go hand-n-hand with the GSR's ECU. Have you ever noticed the GSR's Vtec kicks in earlier than the other Vtec powerplants with single stage manifolds? If you decide to get an aftermarket manifold then go with the Skunk2 and change to a chipped P28 or P30 ECU to match the power band. __________________
<span style=\'color:red\'>14.2:1 CR LS with 405A's and working out the bugs</span> <u>Fastest 60ft</u> 1.78 <u>Best ET on 1/8th</u> 8.42 <u>Fastest MPH</u> 82.23 mph All Motor LS (B18B) <span style=\'color:green\'>Hasn't been tuned yet!</span> |
#8 |
Ride: 01 is300, 05 s2000, 03 rx300
i wouldn't go as far as to say its an "easy install" there are a lot of things you have to worry about if you dont have access to a hoist etc. you will alos have to drain quite a bit of coolant.. i did mine when the motor was out of the car, so it was super easy.. but some of the bottom bolts are tough to get to with hand tools on a b series...
#10 | |
#11 | |
B16, if you can, please explain to me what is going on with my car. (the 4400 VTEC thingy) ![]() __________________
#12 |
hmmm that's weird- i guess scott's gsr was fucked up then, because there was def. a buttefly change before the actual came change over
or at least some change that didn't feel like a full cam changeover- oh well, my bad |
#13 | ||
#14 | |
#15 |
^^^^^^^^no- this part i at least know- haha it's the secondary butteflies in the intake- GSRs have a two stage intake, the butterflies that we are talking about are what switches between the long runners and the short runners
yeah i guess so- it just seemed like there was an audible sound change before full on vtec hit- oh well i'm a tard- hopefully i'll remember better once the gsr is in my civic |
#16 | |
#18 | |
haah, no, both cams go into vtec... like slammed said, its your secondary butterflies in the intake manifold that open up at the later RPM.
#20 | |
#21 |
Thats fucken tight! I never knew that either. Just makes me love my DOHC VTEC even more.
Thanks B16!!! __________________
| Euro-R (Accord) Intake Manifold on H22A | JDM7o3 | HYBRID -> BA-BB /CA-CD | 17 | 09-20-2004 12:47 PM |
| which intake manifold | Sed8ed | Engine Building | 6 | 07-08-2004 09:58 PM |
| B16a intake Manifold question | Jdubspeeds | General Tech and Maintenance | 1 | 04-02-2004 11:35 AM |
| ITR Intake Manifold on a B16a sir2 head | pissedoffsol | General Tech Articles | 0 | 01-11-2004 08:51 PM |
| EX intake manifold on a D series engine | Liquidblaze | General Tech and Maintenance | 4 | 08-06-2003 07:02 PM |
